Need help determining exhaust backpressure/flow
Old Dec 29, 2008 | 01:49 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Default Need help determining exhaust backpressure/flow
I'm trying to deduce my sidepipes flow rate (since the manufacturer can't find records of that info). More importantly, I'm trying to verify/deny their claim the system is good to 450hp.
According to Lawrence-Keech (makers of my discontinued SideEffects sidepipes), the stock L98 catback induces a 44" of backpressure. When the stock catback is replaced with SideEffects, it drops to 31" of backpressure. Measurements were made at @ 600cfm.
Also, in LK sales literature, it says the sidepipes flow 35% better than the stock catback. The same brochure shows the L98 stock muffler as flowing 275 cfm. Since the muffler would be the primary restriction in the factory catbac, I'm wondering if 1.35 x 275cfm = sidepipe flow per side?
(The total system flow would be about 750cfm I'm thinking).
OTOH, since there's more than 28" of backpressure at 600cfm, should I assume the sidepipes actually flow a bit less than 600cfm?
My ultimate goal is to determine how much power the sidepipes rob from a 450hp motor (measured at the crank). If not, I'm hoping someone can at least make sense of the numbers provided and determine if the two measurements are consistent -- pointing to the correct cfm for the system. Using that, I could figure it out.
Last edited by GREGGPENN; Dec 29, 2008 at 11:35 PM. Reason: Reworded post for clarity
Old Dec 30, 2008 | 09:57 AM
Aurora40's Avatar
Aurora40
Is that 44 in-Hg? Or some other " measurement? That's like 1.5 ATMs or 22psi if it's inches of mercury, that seems insane for backpressure.
Old Dec 30, 2008 | 11:07 AM
tequilaboy's Avatar
tequilaboy
The values listed appear to be in units of cm of mercury not inches.
44 cmHg = 8.5 psi
31 cmHg = 5.994 psi
These appears to be reasonable values for back pressure.
You can add a pressure tap somewhere in the exhaust system and measure it to confirm.
Also for 450 crank HP, you would want the entire system to flow approx. 990 cfm (450 x 2.2) or 495 cfm per muffler. It would appear that your mufflers fall short based upon the posted information.
Old Dec 31, 2008 | 01:32 PM
GREGGPENN's Avatar
GREGGPENN
Originally Posted by tequilaboy
For 450 crank HP, you would want the entire system to flow approx. 990 cfm (450 x 2.2) or 495 cfm per muffler. It would appear that your mufflers fall short based upon the posted information.
I have seen Vizzard's formula and was pretty sure the SE sidepipes were less than that. His formula was the basis for my question. I really wanted know how restrictive they'll be.
One email I got says 30hp for a short-runner intake (shifted around 6k rpms), but only 5hp for a hogged out TPI that gets shifted around 5k rpms. (Of course the TPI doesn't develop 450 crank HP either -- with everything else being held constant in a simulation).
To Need help determining exhaust backpressure/flow
