Alternator ??? help
Old Dec 29, 2008 | 05:18 PM
dustmann's Avatar
dustmann
Default Alternator ??? help
At the alternator and battery has 15.20 volts when running. The dash shows 11.20 and the car runs sluggish. Is the built in regulator bad and not putting volt to the dash for a warning light to come on. What do I check or do next? Thanks Douglas
Old Dec 29, 2008 | 05:30 PM
MikeC4's Avatar
MikeC4
Do you have a good working digital voltmeter ? 15.2V is to high. If this is correct, your voltage regulator diodes may have blown and the voltage is not being clamped properly.
As far as the 11.2V, this would be too low !!!!
I would first check Alternator and battery terminal connections.
Old Dec 29, 2008 | 05:31 PM
Iroc57's Avatar
Iroc57
Th first thing that I would check is your ground (-) to the block. It could be that simple if you haven't already. Clean it up and see if that made a difference in the voltmeter. If the car is starting when you leave it it may just be a dash problem as well. You would have trouble cranking long before it would run "sluggish" in my experience.
Old Dec 29, 2008 | 05:49 PM
dustmann's Avatar
dustmann
Default Thanks guys
I went back and checked what you said. My digital voltmeter is more HI-TECH than I am. I had it sent wrong. After I put the battery charger on the battery. It would not start now. The volts are low, 11.20 with the car running. The same as the dash. I will take it in for a rebuild. Thank you guy.
Old Dec 29, 2008 | 08:13 PM
MikeC4's Avatar
MikeC4
Good deal. Yeah, your car electonics will start going bonkers when at lower voltages causing all sorts of drivability issues. Your new or rebuilt, or reamnufactured unit should put out approximately 14.3V
Old Dec 29, 2008 | 10:25 PM
jfb's Avatar
jfb
Batteries are considered discharged at 12.0 volts and fully charged at 12.9 v or higher (max is 13.2 v). Normal alternator output is 14.7 volts cold and they drop to 13.7 volts hot. Dash voltmeters read 0.3 volts lower due to 0.3 volts drop across the ign sw contacts. 15.2 volts actually is within GM's tolerance for alternator output (max is 16 v). You should have seen the red battery symbol light on with the engine running at 11.2 volts.
Old Dec 29, 2008 | 11:07 PM
MikeC4's Avatar
MikeC4
This is interesting information. I would think if someone had an alternator that was putting out 16V, this could potentially harm ECM and other electronic components.
Huh
Old Dec 29, 2008 | 11:37 PM
jfb's Avatar
jfb
Nope, nothing in your C4 will be harmed by 16 volts across the battery. All the sensitive electronics has a voltage regulator supplying the electronics that can easily handle an input voltage of 16 volts.
Old Dec 29, 2008 | 11:50 PM
JimiHendrix's Avatar
JimiHendrix
Your battery self discharged like that? Make certain you don't just have a faulty battery with an internal short in it. If your alternator is putting out excessive voltage. . . and it is still not charging the battery. . . I would suspect the battery first, battery connections, and then alternator.
In any regard, whenever I've had an alternator issue, and the battery has some time on it (2+ years). I change BOTH and be done with it. A bad battery can overwork a new alternator and it won;t show up until a good time later when you will be replacing both.
Good luck with it!
To Alternator ??? help
