As you all know, both cylinder heads are drilled and tapped to accept the temp sender for the analog coolant temp gage. Of course only one cylinder head gets the sender while the other is simply plugged. I need to buy a plug, does anyone know the size? I don't have a tap that big in order to measure it and I really don't want to lug a cylinder head into the hardware store
5/16 or 3/8 are usually the most common plug sizes. Why dont you take the sender to the hardware and match it up if its the same size hole in both? Its alot lighter than the head, lol. Another thought is that pipe plugs in this range are less than a buck, go get a couple different. You may wanna go to an automotive supply with the sender as sometimes the thread pitch can be different. The plug will start and tighten, most likely it will work but if you decide to do something different later on, the threads may be buggered up. Hey I am a plumber, what can you say, get the right thread pitch!
The sender is at the machine shop with the old heads that are being gone thru. I'm headed out in a bit and thought someone may know off the top of their head. No big deal.
You can buy 3/8 - 18 NPT and be "confident" of the fit.
I only sent you to the "chart" because I assumed that you likely had the cylinder heads and it's a simple measurement to convert to the correct NPT. Why NOT just have the "shop" that's got the cylinder heads install the plug while the pair is there!
It is a good bet that they will have them lying around
