Bose Conversion on 91
Old Jan 1, 2009 | 07:42 PM
Stingray1970's Avatar
Stingray1970
Default Bose Conversion on 91
Well, I've finally decided to can the Bose in my 91 coupe. However, I don't know what to replace it with. I would like to have a tuner with amber lighting to match the rest of the dash. I know most Bose users have or want to change. I'll appreciate any suggestions.
Thanks in advance,
Gene
Old Jan 1, 2009 | 07:57 PM
Demonic85's Avatar
Demonic85
Take all of the old stuff out. Go find a nice head unit and some speakers you like, 5" are pretty popular. If you like subs a 10" will fit in the hatch storage area. Buy all new wiring, the thicker the gauge, the better. Get at least 16 gauge though. Have fun wiring it all up
Old Jan 1, 2009 | 08:19 PM
Stingray1970
Thanks for your speedy response. I'll probably order something in a few days.
Gene
Old Jan 1, 2009 | 10:11 PM
-=Jeff=-'s Avatar
-=Jeff=-
My Nakamichi CD400 lights match almost perfect
Old Jan 1, 2009 | 10:55 PM
l98tpi's Avatar
l98tpi
Max G’s
There was a thread on this same subject a couple of weeks ago. I went to Best Buy and had a complete ALPINE system installed. Also, if you were interested, a Navigation System will fit nicely into the old stereo location.
Old Jan 2, 2009 | 09:44 AM
vetteman42's Avatar
vetteman42
Active Streak: 90 Days
l98tpi: Thinking about a switching out my '91 system too! Did you have them deinstall and install new system. And can you provide the ALPINE model number, speakers, etc and approximate total cost...Many thanks!
SAVE THE WAVE
Old Jan 2, 2009 | 11:39 AM
aklim's Avatar
aklim
Seems to me like the only way to fix this is to run a set of wires for your speakers and install a different head unit or am I wrong?
Old Jan 3, 2009 | 07:56 PM
l98tpi's Avatar
l98tpi
Max G’s
SAVE THE WAVE
They did remove the complete old system and install the new. The CD/Receiver is an ALPINE CDA-9847 and is mp3 and sat capable. Not sure on the speaker models, they're covered by my speaker covers and it has been about 3yrs ago when I had the system installed. I would recommend Best Buy, they did very good work.
Old Jan 4, 2009 | 10:21 AM
vetteman42's Avatar
vetteman42
Thanks appreciate your response!
SAVE THE WAVE
Old Jan 4, 2009 | 09:19 PM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
I have heard some horror stories about Best Buy and Circuit City installs, So be careful. I replaced everything in my car a couple of years ago, was not too bad, and it sounds great; I am just getting ready to upgrade the system w/ an Arc Amp and Focal speakers up front, and two 8" subs in the rear speaker compartments.
Here is a picture of my HU, an Eclipse CD2000, w/ a Vrum Vrum mounting hardware.
Old Jan 5, 2009 | 05:31 PM
Yorcci's Avatar
Yorcci
And if you're going to use the original antenna, here is the pink wire where to apply 12 V from the head unit's remote voltage supply (or whatever it's called) to get the antenna up. It's located on the RH side of the radio unit:
(The pink wire, which has already been cut in this picture.)
To Bose Conversion on 91
