84 shifting
Old Jan 4, 2009 | 02:26 PM
defo98's Avatar
defo98
Default 84 shifting
Is there any way to keep my 84 from shifting into a high gear when just cruising at like 35mph. It always seems to shift so high and almost struggle cruise.
Old Jan 4, 2009 | 06:13 PM
qws's Avatar
qws
Assuming its an automatic just put it in "drive" rather than overdrive.
Just out of curiosity have you ever adjusted your tv cable?
Old Jan 4, 2009 | 07:02 PM
Corvette Chris's Avatar
Corvette Chris
Thats what I do when I'm driving around that speed.
Old Jan 4, 2009 | 08:42 PM
Iroc57's Avatar
Iroc57
Adjusted properly it will shift to third (D) around 33MPH. What you are feeling may be the TQ lock up cycling.
Your car is running as it should, if you want to get higher cruise rpm you can shift it manually and hold it in 2nd until you get up to 45 or so.
To 84 shifting
