Bosch III Injectors
anesthes@cisdi.com
I was gonna buy a set of these a while back and have rich @ cruzin performance test them to see what they actually flow. Did you buy the modified ones?
-- Joe
anesthes@cisdi.com
-- Joe
I'm using the Bosch III, part # 198R53. For L-98 engine.
General Motors Multecs: These are more likely to be shorted than not! We throw away approximately 65 percent of all GM Multec cores. Each Multec is tested under a loaded (on) condition with a current load unit and a scope. (This test is repeated approximately four to five times per injector from beginning to finish.) Many bulletins have been offered from "The General" on this subject and why it occurs, but in reality it doesn't matter since they are the only injectors that have had this particular pattern failure; other units run for hundreds of thousands of miles without the problem So why opt for this. there is even a TSB put out by the General back in 94 stating not to use any cleaners on these injectors as it will accelerate the failure. So we came up with an affordable solution.. This forum alone has many posts on how these injectors have improved the performance and reliabilaty of the C4. This is what we care about.. We do not care what Rich at Crusin thinks or what Joe Anetheses thinks. If you buy our injectors they will work better than the multec ever did, Thats a fact evidenced by the countless numbers of customers with these.
if one fails we will replace it FREE with no questions, and if there is a problem we will find the fix. End of discussion
Jon Jr.
Seeing as I did not bring up competitors or others opinions, I'm not sure why that was pointed out for me.
Let us not forget about Jon's top notch customer service and that he continuously contributes to this forum in a POSITIVE manner.
mseven, just curious. What would you recommend as a replacement for the original Multecs?
anesthes, I sent you the Datamaster file, what are your thoughts on the data?
I do however like the new tech in the III's. My only thought was determining the difference of lbs/size at what fuel pressure becomes important. This is needed to understand what size inj.(lbs.) would equal the existing size inj. at 43.5 psi. (instead of an inj. rated at a higher or lower psi.). Reading their posts gives me the idea that they understand how fuel pressure will change fueling, and will directly effect lean/rich, blm, etc.etc.
BTW, there are a few others aside from multecs I wouldn't use. ACCELS for one a few years ago were a realistically priced replacement. However, there were many here who tried them in the past with out good results...........and no vendor support
How many miles on the engine?
Do you have any DTC set ?
What is your fuel pressure?
The LTx engines are notorious for "Opti" issues.
Do you have access to a scanner and a FSM (IMHO both must haves)
Hopefully others with a better understanding of the LTx motors will chime in.
Since I've started restoring this car I've sunk a lot of $ in it.. I must say that so far these injectors from Jon have given me the most bang for the buck!!
-- Joe
-- Joe
The new-to-me '92 LT1 coupe that I bought last September had, and still has, some definite driveability bugs that I've been slowly working through. With the help of my mechanic, we've addressed a number of issues, and each repair has brought us small but positive results. Over the winter I purchased an Auto X-Ray scanner and had posted some numbers up from it on the "other" forum.
In a nutshell, from a cold start in open loop, both (right and left bank) BLMs were locked on 128. As soon as the system went closed loop, the right BLM shot up to 160 and was pegged there at idle, but would come back down under acceleration/driving. The left BLM in closed loop was in the 130 range, give or take a few. My initial suspect was 02 sensor(s) and/or injectors. My injectors all checked within range as far as resistance goes, both hot and cold, and fuel pressure was bang on at 42-45 psi and held there with a fairly slow bleed-off. Just yesterday, I had both of my 02 sensors and my in-line fuel filter changed. When I drove the car home from the shop, I had my scanner hooked up. Now, in closed loop at idle, both BLMs are right around 110-115 and 120 - 125 while accelerating/driving. I also noticed that with the old 02 sensors, the readings (especially on the right sensor) were kinda' whacky, making changes between lean/rich very quickly at times and very slowly at others. With the new sensors, the lean/rich changes are much more consistant and steady, and I'm seeing actual lean/rich/lean/rich changes whereas with the old sensors it would sometimes go lean and stay there for long periods of time before changing.
The car does seem to run SLIGHTLY better now, and I was able to pass my state's emissions test yesterday with flying colors, however, the idle is still fairly uneven. What I've been calling "bouncy". I just received a set of 22# Bosch IIIs from Jon at FIC this week, and I'm hoping to get them installed tomorrow morning. We're expecting lots of rain here tomorrow so even if I do get them installed, I doubt I'll be inclined to do a lengthy road test. As soon as I do though, I'll get some data from my Auto X-Ray and from the scanner built into the seat of my pants and post the results here.
I'm sincerely hoping to keep our 'Vette for a long time, so it was natural that I would want to get to know how it ticks, but I never, NEVER, thought I would come to learn this much about Corvette fuel injection in my life!
Ron
