headlight issues
Old Jan 5, 2009 | 01:39 PM
Hanny93's Avatar
Hanny93
Default headlight issues
I need to replace the gears in the head light motors.
What do you suggest plastic or metal and were to get them.
Thanks.
Old Jan 5, 2009 | 02:18 PM
aminnich's Avatar
aminnich
You probably just need the bushings. Plastic in any event. And MidAmerica is the vendor I prefer.
Old Jan 5, 2009 | 06:41 PM
HANK AZ.'s Avatar
HANK AZ.
Three bushings per side mine were cheaper at Eklers. Do both sides my left was working fine the right would only open half way. When I took them apart they were in the same shape so it wasn't long for the drivers side.
Old Jan 5, 2009 | 08:16 PM
devildog's Avatar
devildog
From: fighter pilots make movies, bomber pilots make history
Default Use local 1/2 dia dowel x 7/16 length
Tom,
It probably is just the three 'spacers'. I just did mine and cut 1/2 inch dia. wooden dowel. It worked great. About 2 hours to do both. Removed only three motor mounting screws and roll pin. Set a piece of plywood at the wheel and used as work area...did not remove wiring.
There is a good thread about this repair. Some people found teflon and other plastic spacers in hardware stores that worked just fine.
it is only a few dollar from the suppliers, but faster to cut than make the order.
Joe
Old Jan 6, 2009 | 07:44 AM
runner140*'s Avatar
runner140*
Bushings and plastic. If you use metal, you will break something bigger and more expensive. They look like this:
Old Jan 6, 2009 | 11:45 PM
GKK's Avatar
GKK
The Plastic headlight motor Gear is recommended as the most reliable replacement.
To headlight issues
