AC Compressor New vs. Rebuilt
Old Jan 7, 2009 | 11:19 AM
jakers's Avatar
jakers
St. Jude Donor '06
Default AC Compressor New vs. Rebuilt
I have been putting off getting my AC compressor repaired/replaced for months. Primarily because of money issues. Tough economy and dollars are in short supply.
Prices are all over the place. $249 for a rebuild all the way up to a $1,000+ for a new one. I currently have two cores. I have seen the Partsladi on Flea-Bay offer some pretty good prices for an OEM compressor and clutch (was $495). Those prices appear to be gone. The prices have increased, The Partsladi sells the Clutch ( Now $500) and the Compressor ( Now $250) seperately. So I am considering a rebuild on my compressor. I am curious to know if the rebuilt's are any good or if I am simply wasting my money. I will need to start looking at this decision. As we all know you cannot drive a car in Georgia from June through October without AC.
Give me your feed back please.
Old Jan 7, 2009 | 11:33 AM
SunCr's Avatar
SunCr
I've never bought a rebuild, but the last new I bought - from Autozone for my truck - was broken out of the box. If yours isn't seized and maybe only needs a shaft seal, you can fix that for about $50.
Old Jan 7, 2009 | 12:00 PM
jakers's Avatar
jakers
St. Jude Donor '06
I would be interested in fixed it, if I can... Can you direct me to some resources for parts/tools. I do have a FSM, however, I have never looked to see if it detailed AC compressor rebuild.
Clutch rebuild? Just buy new?
Old Jan 7, 2009 | 12:43 PM
SunCr's Avatar
SunCr
I don't know what year or compressor you have, but assuming it's a Nippo ('88 up), here's a link I've posted in the past: http://www.pelicanparts.com/techarti...so_rebuild.htm The fundamentals are the same. You don't need any special tools. Clutch is removed by holding it with a strap wrench or oil filter wrench pliers while you loosen the shaft bolt with a 10mm socket. Pulley and coil are held on with snap rings. Pulley bearings are servicable but they're pressed in - a Napa with a machine shop could probably handle it for a few bucks. More info is available on the Board at www.ackits.com - their FAQ's come in handy and they're more than happy to help.
Old Jan 7, 2009 | 01:07 PM
vader86's Avatar
vader86
I bought a rebuilt one from The Last Detail, and its worked fine for 6 years. I'd go that route considering the prices they ask for them.
Old Jan 7, 2009 | 01:44 PM
jakers's Avatar
jakers
St. Jude Donor '06
Great reference material.
Old Jan 7, 2009 | 01:45 PM
jakers's Avatar
jakers
St. Jude Donor '06
The car is a 94. So yes the compressor is the Nippo. From the tech article it appears to be a similar compressor to the 911? The rebuild looks straight forward. I can handle that. thanks
Old Jan 7, 2009 | 02:40 PM
cumbercr's Avatar
cumbercr
Avoid rebuilt if at all possible. I installed one that lasted a month. That wasn't bad enough, it scattered crap through the whole system. I ended up replacing the compressor, receiver, orifice and condenser. They gave me my money back but that didn't cover the cost of all the other new parts, flushing, evacuating and recharging.
Old Jan 7, 2009 | 03:22 PM
SunCr's Avatar
SunCr
The Porsche, Lexus and all the Nippos seem to come apart the same way - the only thing you can't find are the internal specs but the weak link seems to be the shaft seal and if you catch it in time (before all the oil is gone or it's grooved the shaft) it's not difficult to fix. If you go over to the ackits board they pretty much rag on the discount warehouse rebuilds (which is why I thought I'd try a "new" one). I too bought new from the Last Detail. It came sealed and with oil in it. The clutch assembly was a separate deal and it bugs me that you have to shell out another 9 to 12 Bucks for the shim kit.
Old Jan 7, 2009 | 07:00 PM
RatC4's Avatar
RatC4
I bought the new and a receiver dryer at this link a couple years ago and it's been working fine. The service from the company was good too.
Old Jan 7, 2009 | 10:25 PM
Yguy's Avatar
Yguy
I've been looking into the same thing for my '88. When I got the car in '94, BUD'S rebuilt the compressor for me and got the AC runing right.
Now 14+ years later it's starting to throw oil out from behind the clutch.
The price I got from the local dealer was in the high 400's, and that includes the installed clutch. If you guys know how to change the front seal, I might look into doing just that. Can this be done on the car, or is it a remove for surgery type deal?
Old Jan 8, 2009 | 03:00 PM
SunCr's Avatar
SunCr
You need to discharge and remove it - see the link I posted for how to repair it. Seal kits are about $50. You will also want a new Accumulator and you should R & R the orifice as that leak creates more wear and all the little shavings end up in the orifice screen plugging it up. If you don't clean or replace it (like I did the first time I fixed one) good possibility it won't make cold air meaning you'll have to take it all back apart and recharge.
To AC Compressor New vs. Rebuilt
