Replacement Gas Struts for Hood?
Old Jan 19, 2002 | 09:04 PM
KYVette90's Avatar
KYVette90
Default Replacement Gas Struts for Hood?
Where can you get replacement struts, cheap? My 90 only has one on it. If I'm not mistaken, there are additional spots for two more little ones. If I add these will my hood pop up automatically when I pull the hood release handle?
Old Jan 19, 2002 | 09:27 PM
TravisD's Avatar
TravisD
Default Re: Replacement Gas Struts for Hood? (KYVette90)
My only question is why would you want this? Sounds dangerous - think hood not latched properly, and body flex, while driving 55 MPH.
Old Jan 19, 2002 | 11:06 PM
yellow86c4's Avatar
yellow86c4
Default Re: Replacement Gas Struts for Hood? (TravisD)
I don't think it's supposed to pop all the way up. I think they make it much easier to lift and close the hood. I have an 86L so mine has the two small ones and the large one. All of mine are shot and I am considering replacing them. Mid America and Ecklers has them but they are not cheap.
Old Jan 19, 2002 | 11:17 PM
jimbos86vette's Avatar
jimbos86vette
Default Re: Replacement Gas Struts for Hood? (yellow86c4)
Do these little struts REALLY help??? My hood feels like I'm lifting 100 pounds or so when opening.
Old Jan 19, 2002 | 11:29 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Replacement Gas Struts for Hood? (jimbos86vette)
When I got my Vette in 2000 one of the small ones was missing. Though it was a bear to compress for installation it didn't seem to help noticibly. Maybe I need to replace all of them.
Old Jan 20, 2002 | 12:48 AM
Rascal's Avatar
Rascal
Try 'The Last Detail' 88-96 hood support $53.00. Ecklers is $66.99. http://www.TLD-Corvette.com
Phone 770-414-0077
Hope this helps!
Old Jan 20, 2002 | 01:47 AM
Aggravated4life's Avatar
Aggravated4life
Default Re: Replacement Gas Struts for Hood? (Rascal)
I got mine from autozone..the brand is called mighty lift.I replaced the large main strut and the 2 small ones.Mine were all SHOT and the hood was so heavy feeling.
(LIFETIME WARRANTY on THESE)
By just replacing the 2 small ones, the hood woud stand up on its own.The new small struts were so stiff I had to push the hood past the raise point to install the new ones to clear the catch socket.Btw,if youre missing the 2 small struts,you need the clips that keeps the struts from falling out.
Then I Installed the new main one...the hood popped much easier and was easier to lift after.If it doesnt pop as much,you can also adjust the plastic cable nuts with two 13MM wrenches at the latches.Lock down the long nut and turn the short one at the end and it will pull or move the latch in or out to the desired place
BTW,one day I was doing a brake job up front and the car must have shooked some and the hood fell down and hit the back of my neck!!
Lucky for me,it was the curved part over the front tire and it just pushed my neck down when it slammed down...had my head bent down doing the brake work and never knew what hit me...if that part of the hood was flat,my neck wouldve been broken..I was sore for days..so I ran out and got new struts and learned a valuable lesson.
Old Jan 20, 2002 | 02:24 AM
scorp508's Avatar
scorp508
Ours have no hydraulic assist, it was added in 1988.
Old Jan 20, 2002 | 11:13 AM
Rich B.'s Avatar
Rich B.
No. I replaced my '86 with GM struts; no difference in lifting, but it will stay at the full open position better.
I'm thinking about replacing the long strut (just a locking rod on the '86) with a later model replacement gas strut, for a total of 3 struts.
And driving with the hood unlatched is not much of a problem. It does lift an inch or two at speed; but passing motorists will alert you...(They'll have eyeballs the size of dinner plates)... :eek:
[Modified by Rich B., 10:15 AM 1/20/2002]
Old Jan 20, 2002 | 01:17 PM
mash557's Avatar
mash557
Default Re: Replacement Gas Struts for Hood? (Rich B.)
I'd think that the aero downforce on the front pivot hood would keep it pretty well down and not a big problem.
To Replacement Gas Struts for Hood?
