Which Rack?
Old Jan 8, 2009 | 10:58 AM
tgs87's Avatar
tgs87
Cruising
Default Which Rack?
I checked the RPO codes and none show FE7,Z51 or Z52. So if nothing is listed, I guess then I have a base rack on my 87. So which one do I order? Would there be issues if I changed to the heavy duty or Z52 rack, other than the 2 vs 2.5 turns lock to lock ?
Thanks Tom
Old Jan 8, 2009 | 12:26 PM
C4forlife's Avatar
C4forlife
You can change without a problem. All of the racks 84 - 96 are interchangeable. Good example I have a 86 with a 84Z51 rack that is using 96 power steering hoses to work with the LT1.
Old Jan 8, 2009 | 12:29 PM
shakedown067's Avatar
shakedown067
St. Jude Donor '12-'13
Nope they mount the same. I switched to a 91 Z51 unit on my 96 so I could get a quicker ratio. I really dig it!
To Which Rack?
