aluminum flywheel?
Old Jan 20, 2002 | 04:56 AM
Pete89's Avatar
Pete89
Default aluminum flywheel?
is anyone using a singlemass aluminum flywheel or know where i can find one?
Old Jan 20, 2002 | 06:18 AM
ASRoff's Avatar
ASRoff
Default Re: aluminum flywheel? (Pete89)
Give star engineering a call (do a web search) I have there stage III carbon fiber clutch and aluminum flywheel. Three words; VERY GOOD CLUTCH!!!! :cheers: :seeya
Old Jan 20, 2002 | 11:32 AM
Rich B.'s Avatar
Rich B.
TPiS has a 12.5 # alum flywheel; $450...part # 800-900 all 1-piece rear-seal crankshafts; # 800-910 all C5's...
Old Jan 21, 2002 | 12:36 AM
The Dingo's Avatar
The Dingo
CI 6-7-8-9-10 Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-‘17, '22
Living in Oz, I'm not the best person to say WHERE to buy one but Mcleod, Borg Warner, Fidanza, TPIS & Kurt White (I think) can supply aluminium flywheels.
Kurt's e-mail is KNJW1@aol.com, for contact details for the others maybe someone else here can help.
I'm of the impression that you need to be careful to make sure the flywheel either suits an internally or externally balanced motor.
I have a cast iron aingle mass flywheel from DRM. Having a definite performance bias in what I want from my car I am very happy with it and will not go back to a dual mass. Be advised that your gearbox will be quite a bit noisier with the single mass, both at idle and at certain part throttle rpms (the latter doesn't seem to be experienced by everyone with these setups...). Using a sprung clutch disc will lessen the gear rattle you will hear with this setup a little but will not eliminate it.
HTH
Old Jan 21, 2002 | 12:51 AM
AS84's Avatar
AS84
Default Re: aluminum flywheel? (Red 90 L98 Coupe)
The more I hear about the single mass flywheel the more I tend to believe that one is in my car. My car has a gear box rattle at low idle. Doesn't matter if the clutch is in or out either. I get to find out for sure next week when the spec II goes in.
Old Jan 21, 2002 | 01:05 AM
ASRoff's Avatar
ASRoff
HTH
no rattle here with the aluminum setup (It is machined to locate the throwout bearing the proper distance)
Old Jan 21, 2002 | 02:05 AM
XtremeVette's Avatar
XtremeVette
Original Founding Member!
Cruise-In 1, 3, 9. 10 & 11 Veteran
Default Re: aluminum flywheel? (ASRoff)
do you really gain anything by going to aluminum?
Old Jan 21, 2002 | 03:12 AM
ASRoff's Avatar
ASRoff
Default Re: aluminum flywheel? (XtremeVette)
You reduce paracidic loss. The engine uses horsepower to turn that heavy flywheel (beleave me a dual mass is heavy!!!!)although a heavy flywheel makes it easyer to move the car (with the aluminum flywheel you have to "feather" the clutch more) as soon as you let the clutch out that heavy flywheel robs power. It's also why drag racers use lighter wheel's for every pound you take off of the rotating assemblys (be it the flywheel or car rims or driveshafts) its like removing 2 lbs. :cheers:
Old Jan 21, 2002 | 09:04 PM
The Dingo's Avatar
The Dingo
HTH no rattle here with the aluminum setup (It is machined to locate the throwout bearing the proper distance)
Gee, thanks, now I have another reason why I should have gone for an aluminium wheel instead... :rolleyes: :jester. (Happy with my current setup but if I redo this part of my car, I will be using an aluminium flywheel next time...)
Glad you replied, now things make a bit more sense :).
Old Jan 21, 2002 | 10:43 PM
ASRoff's Avatar
ASRoff
Red I know your plight I had a TPIS conversion with a ram clutch disc it sounded like a rattle snake on speed!!!!!The SPEC flywheel is as quiet as stock.
Old Jan 21, 2002 | 11:16 PM
AKS Racing's Avatar
AKS Racing
I run the SPEC aluminum flywheel as well, no noise. But, the exhaust is quite loud, so I probably would not hear it anyways.
Aaron
[Modified by AKS Racing, 9:17 PM 1/21/2002]
Old Jan 22, 2002 | 03:50 AM
ASRoff's Avatar
ASRoff
Default Re: aluminum flywheel? (AKS Racing)
One other thing That aluminum flywheel sure makes the engine spin up fast when you blip the throttle right AKS? :D
Old Jan 22, 2002 | 04:18 AM
BlackRocket's Avatar
BlackRocket
Hey Pete, I have a brand-new 12# Fidanza aluminum flywheel that I need to send back to TPIS since I can't use it with the engine I am building. I paid $450 back in August and TPIS requires a -20% restocking fee to return it. I will let this go for $450 - 10% or $405 if interested. This saves you $45 + their huge handling fees of $15 for a total savings of $60. Let me know if interested. I also have a TPIS 7QT road race oil pan if interested that I can make the same type of deal on!!! :D :D :D
To aluminum flywheel?
