Wheel offset
Old Jan 11, 2009 | 08:38 PM
buddylee432's Avatar
buddylee432
Default Wheel offset
I am looking at new wheels for my 85. Will a 43mm offset work fine and clear everything?
Old Jan 11, 2009 | 08:54 PM
rodj's Avatar
rodj
Stock is 38mm / 56mm on '88+
Old Jan 11, 2009 | 08:57 PM
buddylee432
so anything over 38mm will work?
Old Jan 11, 2009 | 09:16 PM
project C4's Avatar
project C4
how wide are the wheels ?
Old Jan 11, 2009 | 09:19 PM
buddylee432
Made by Eagle they are 43mm offset and width says 8j so I am assuming 8 inches.
Old Jan 11, 2009 | 09:29 PM
project C4's Avatar
project C4
if the wheel is 8 inches wide they will work but they will be sitting in the wheel wells pretty far. They will need 1/2" spacers to put them out in the correct location.
Use this web site to help
http://www.joby.se/corvette/div/corvette_wheels/
Old Jan 11, 2009 | 09:42 PM
c4cruiser's Avatar
c4cruiser
At 43mm, that's only a 5mm difference in offset or just under 1/4". You shouldn't notice that. What you should be careful with is clearance between the inside of the wheel center and the calipers.
Wheel width has an impact on tire fitment. If you are keeping the stock 255/50-16 tires, you really need a 9 to 9.5" wide wheel. 8J most likely refers to the width and that will be too small for the 255 tire.
Also verify the bolt pattern. GM wheels typically are listed as a 5 x 4 3/4 pattern but the specs are actually in mm or 5 x 120.6mm. GM OEM lugs have a 60 degree taper; if the new wheels use a different taper, you will need new lug nuts.
Old Jan 11, 2009 | 09:45 PM
buddylee432
I have the 245/50 16's. Will it work with the 8 inch wide wheel?
To Wheel offset
