Jack me up
Old Jan 14, 2009 | 11:08 AM
trowel4's Avatar
trowel4
Default Jack me up
Anyone have some input on proper places to put jack stands under a 1994?
Old Jan 14, 2009 | 11:10 AM
pianoguy's Avatar
pianoguy
Go here and get the Towing and Jacking pdf:
http://tinyurl.com/6c7zyy
Old Jan 14, 2009 | 12:19 PM
janarvae's Avatar
janarvae
Error message - don't have access to this area.
In the front, you can put the stands under the frame rails between the 2 triangles. You'll have to get down on your knees to see it. You can also put the stands further towards the front where the frame curves inward towards the engine. I use these points for the stands so I can jack it up using the side rails.
For the rear, you can jack up with the frame rails again, between the 2 triangles and place the jacks there. I jack up just behind those points and inward where the frame makes a 90* angle and place the jacks under the side frame rails. I had the car over 2 ft in the air for 6 months or so and removed and installed exhaust and transmission using these locations.
Old Jan 14, 2009 | 12:26 PM
pmihaltian's Avatar
pmihaltian
Slingshot
Here - try this:
File Type: pdf
Old Jan 14, 2009 | 12:41 PM
trowel4's Avatar
trowel4
Thanks for your advice. Is it safe to use shock absorber bottom mounts?
Old Jan 14, 2009 | 12:52 PM
janarvae's Avatar
janarvae
I would think that could harm the suspension? Stick with the frame.
Old Jan 14, 2009 | 11:56 PM
lostnfoundC4's Avatar
lostnfoundC4
Great information-Thanks!
Old Jan 15, 2009 | 04:59 PM
El T1's Avatar
El T1
Originally Posted by pmihaltian
Here - try this:
That PDF is decent, but pre-LT1... (which matters when jacking up the rear end).
On my '95 the exhaust comes right below the differential, and so any rear jacking can't readily be done from the center.
I've been jacking up just outboard of the exhaust pipes and differential, on some beefy looking suspension attachment points. I have no idea if I'm damaging anything or knocking anything out of alignment by doing this, but there I am...
I'm very close to making a jack adapter to work around the pipes, yet still jack up the car from the center... haven't done that yet, though.
Old Jan 16, 2009 | 08:23 AM
lostnfoundC4
I picked one of these up at Carlisle last year and it works really well. It slides between both pipes under the dif. A little pricey but it sure comes in handy.
http://www.corvettegadgetman.com/products3.html
I'm a little leery about jacking from the center of the frame rail although some members seem to do it regulary.
Old Jan 17, 2009 | 07:47 AM
Weav's Vet's Avatar
Weav's Vet
Uh.......doesn't anybody have owners manuals with their cars anymore.
Old Jan 17, 2009 | 05:13 PM
El T1's Avatar
El T1
It just shows the frame rails... didn't need a manual for that!
Whoa, cool adapter! Yeah, it's pricey, but I want to support my local entrepeneur and encourage creativity, so I just bought one (yea paypal!).
Old Jan 17, 2009 | 05:36 PM
NEVRL8T's Avatar
NEVRL8T
This might help: http://www.zr1netregistry.com/jackupzr1.htm
Old Jan 17, 2009 | 06:35 PM
El T1's Avatar
El T1
Originally Posted by TheAngelOfDeath
I like the hockey pucks and especially the pads on the jack stands! LOL, that's classic stuff.
I guess I'm too old school, because any car deemed prissy and virginal enough to require pads on jack stands is not likely to end up being driven, and therefore won't end up in my garage...
Old Jan 18, 2009 | 02:39 AM
rayosequis's Avatar
rayosequis
Come on now, how else are you going to polish the oil pan ??
Old Jan 12, 2021 | 11:21 AM
SDE1961's Avatar
SDE1961
I realize the original post was about the C2 label, but I'm hoping folks won't mind a quick, related, C1 label question. What is the correct position to place the C1 Jack Instruction Label on the spare tire covering board? For example: "Center, toward passenger compartment beyond metal cup." or "Offset to right of metal cup.", etc. Thanks for the help!
Old Jan 12, 2021 | 11:23 AM
SDE1961's Avatar
SDE1961
Sorry, realize that this went to the wrong thread. Ignore.
Old Feb 26, 2022 | 06:32 PM
Tommy79's Avatar
Tommy79
Back on sale again @ Costco......
To Jack me up
Old Feb 26, 2022 | 07:06 PM
JETS C3-C4's Avatar
JETS C3-C4
? ? ? ? ? What is ?
Old Feb 26, 2022 | 07:09 PM
Tommy79's Avatar
Tommy79
Default Read the thread...
Originally Posted by JETS C3-C4
? ? ? ? ? What is ?
It's a QuickJack thread.....
No more Beer!!!! Or you can share. I like the dark stuff.
Old Feb 26, 2022 | 07:15 PM
JETS C3-C4's Avatar
JETS C3-C4
I just saw the title of this thread where to jack the car up.
I like the dark stuff too. Too bad you are not closer.
I have a good supply of that dark stuff I would share with ya.
