I have been too busy lately to finish until today. car runs great but I have to manually connect and disconnect the "key on" wire so I'm ready to finish. I looked at alot of pictures of others relays but my wiring looks a little different and I do not want to do it wrong. Here is a pic of my relays. Its a 96 if that makes a difference.
[IMG][/IMG]
Thanks. It's been a while since I wired a relay in. Red is the positive carrier. Black is ground. Yellow isn't used. Blue powers the relay on and connects to the pink wire. White is the (trigger) ground. I think this is correct anyway. I should have a 30 amp Bosch relay & socket around here somewhere.
All done. Looks and works great. I used the relay that meziere recommended with the wp. If anybody is interested in pic's or anything send a PM or something. This forum is great, you made the job way easier.
