Compression ratio question.
Old Jan 14, 2009 | 06:32 PM
Firevette's Avatar
Firevette
Cruise-In X Veteran
Default Compression ratio question.
So how bad would things be if I dropped to 9.5:1? Whats the disadvantage? Can't be that much horsepower given up? Right?:o
Im still gathering parts for my motor, all I really have left is heads to purchase. Im going with the AFR 195's. If I have them milled to 58cc I'll get right around 10.1:1. Or, I throw the extra $300 in the motor somewhere else, and leave them at 65cc and end up around 9.5:1.
What do you think? or ?
Old Jan 14, 2009 | 07:05 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Are you reusing your stock block? What gasket?
Consider 55-56cc if you mill. Everything I read said to pack that sucker as tight as possible. (At least until 11:1 CR is reached).
If you go from 65cc to 56cc, I'm estimating the gain would be 20hp - (5hp from loss of flow*) = 15hp.
15hp for $250ish isn't too bad. If you want the best off-idle response and low-end torque, I'd go for it. That's a lot of what you'll gain.
gp
*according to AFR, ~5hp is the loss from milling 65cc to 56cc
Old Jan 14, 2009 | 07:32 PM
StealthLT4's Avatar
StealthLT4
Here's what you should do:
Leave it at 9.5:1, and you'll actually be able to use 87 octane (which will help with high gas prices)
Then, when you save up some more money for more car projects, supercharge it! You'll already have a low CR ideal for forced induction. At least this is my plan when I build a 427 for my Vette. Sometime...
Old Jan 14, 2009 | 07:42 PM
STL94LT1's Avatar
STL94LT1
I would go for the higher compression.
Old Jan 14, 2009 | 09:23 PM
1989TransAm's Avatar
1989TransAm
I'm not sure you can flat mill them that much. You would probably have to angle mill them to get them down to 58cc. That will pose other problems. I take it you have already bought the pistons? How about having the block decked?
Old Jan 14, 2009 | 10:12 PM
Firevette's Avatar
Firevette
Cruise-In X Veteran
It's a gmpp ZZ4 shortblock that im using. I think GM rates the possible ratios on the ZZ using a .051 gasket. I would be using the gasket AFR reccomends, .041.
Old Jan 14, 2009 | 10:25 PM
Orr89rocz's Avatar
Orr89rocz
Heck if they used a .051 gasket with ZZ4 58cc heads to get 9.6 to 1 or so, a .041 gasket will bring that up .2 right there.
I doubt they used that gasket tho, because .051" gasket on a block that i dont believe is zero decked means the pistons are in the hole another .020-.025 depending, leaving a very large quench height of .070"+. NOT GOOD.
Find out if your block is 9.00 deck or 9.025 and if they pistons lay flat on the top of the block at TDC.
In any case, 9.5 to 1 with aluminum is abit low but still can make some banging power with the right cam. i wouldnt mill the heads
If your pistons are in the hole, run the thinnest gasket you can get away with and still seal ok. .028" should be ok, some have used .015" but thats cutting it close.
I'd still run 93 oct and run aggressive timing. Will help make torque that you lose with less compression
Old Jan 14, 2009 | 11:05 PM
Firevette's Avatar
Firevette
Cruise-In X Veteran
From what I understand its 9.025.
It is a .051 gasket. It allows 10.1:1, with a 58cc head
...ok i need to go find a C/R calculator.
Old Jan 14, 2009 | 11:38 PM
1989TransAm
GM usually puts the pistons down the hole around .025". You need to measureit. Use the GM .028 head gasket as suggested by Orr. That should help in the compression department.
Old Jan 15, 2009 | 12:40 AM
Firevette's Avatar
Firevette
Cruise-In X Veteran
Thats what i used. I came up with 9.85:1 with the .028 and 9.56:1 with the .041.
Old Jan 15, 2009 | 10:10 AM
Aardwolf's Avatar
Aardwolf
Higher compression helps MPG. 1 point is worth around 10 HP.
Old Jan 15, 2009 | 10:22 AM
AKS Racing's Avatar
AKS Racing
Firevette,
I would have the heads milled by AFR to the 58cc vs the "off the shelf" 65cc that AFR also sells. Spend the money now to get the SCR up or you will be kicking yourself that you didn't later. Plus, in order to get down to the 58cc level, requires angle milling, which requires resurfacing of the intake flange, which will be costly later (if you find someone that can do it right, which can be a problem).
Aaron
Old Jan 15, 2009 | 03:30 PM
1989TransAm
I saw it stated somewhere that .030" is about it for flat milling AFR 195cc Eliminator heads. With .006" per cc that would be 5cc with flat milling or 60cc. Angle milling if you want to get to 58cc.
Old Jan 15, 2009 | 04:18 PM
pologreen1's Avatar
pologreen1
I want high compression, because I love snappy cars, and I know I will never super charge this thing now, I would rather have all motor on mine
Old Jan 15, 2009 | 04:55 PM
vader86's Avatar
vader86
If its a question as to which I'd rather have, I'd say the higher compression, but still low enough to run on pump gas.
Higher CR helps efficiency and thus MPG, but higher CR means more expensive gas. I havent done the calculations but I figure that with gas (likely) going back up some, the higher CR will outweigh the detriment in that area.
Old Jan 15, 2009 | 05:53 PM
GREGGPENN's Avatar
GREGGPENN
That's definitely something to look at. When you consider 1 point only gets 10hp, the small amount of increase doesn't seem worth it. OTOH, the break-points for compression vs octane are unclear to me. However, any increase in efficiency or burn quality can help with emissions and mpg. So, the benefits of higher compression seem worthwhile to me as well....
When I looked it up, I found guidelines that showed lower octance gas requires compression to be lower than the 9.5:1 - 10.5:1 range discussed here. IIRC, 8.5:1 lets you run on regular. So, you should run premium gas whether you mill or not (speaking to the OP's config). But, I've also seen people say they're running regular gas and not getting many knock counts.
One of my friends believes his actual stock compression was only 8.8:1 (after measuring cylinder volume), so maybe that's why some cars can run on lower octane. I guess there really is some variation in motor parts!
Old Jan 15, 2009 | 06:46 PM
Firevette's Avatar
Firevette
Cruise-In X Veteran
Originally Posted by AKS Racing
Firevette,
Aaron
Ok, So angle milling cuts the chamber or "deck" side, and the intake side of the head is milled to match the intake? Or is it the flange on the intake milled to match the head?
I think I can get 10.1:1 if they are milled to 60cc and I use #1003 headgasket (.041)
My question is, when will I start running into accesory drive and valvetrain geometry problems? Id like to avoid that, seems that a lot of material needs to go to get down to 58cc.
Originally Posted by GREGGPENN
That's definitely something to look at. When you consider 1 point only gets 10hp, the small amount of increase doesn't seem worth it. OTOH, the break-points for compression vs octane seem fuzzy. Plus, any increase in efficiency or burn quality can help with emissions and mpg, right? So, the benefits of higher compression can be worthwhile.
When I looked it up, I found guidelines that showed lower octance gas requires compression to be lower than the 9.5:1 - 10.5:1 range discussed here. IOW, you should run premium gas whether you mill or not (speaking to the OP's config). But, I've also seen people say they're running regular gas and not getting many knock counts.
10 hp sure dosen't seem like a lot right now.....hmmmm.
To Compression ratio question.
Old Jan 15, 2009 | 06:59 PM
STL94LT1's Avatar
STL94LT1
I have a 9:1 compression C5 and my C4 is ~11:1. The throttle response is so much nicer on the C4, and nothing like the sound of a high compression engine firing up. Just hit the key and BOOM!!
Old Jan 15, 2009 | 07:12 PM
GREGGPENN's Avatar
GREGGPENN
It's basically the difference between removing equal amounts of material across the entire head face vs removing it on a slant (e.g., more comes off the intake side).
No problems with that. I asked the same question. Realize you're not even removing 1/10th of an inch. Doesn't sound like much, huh?
Same deal with the 10hp. But, I am also wanting best possible burn -- having side pipes behind my doors. If you get better burn, better mileage, and better low-end response....
Keep in mind 10hp is a pretty good percentage of the power being made at idle. (see post immediately above this one -- for typical feedback I got on the subject).
Old Jan 15, 2009 | 08:51 PM
AKS Racing's Avatar
AKS Racing
Somewhat true, but angle milling of the SBC cylinder head removes a greater amount of material from the exhaust side, not the intake side. When angle milling the heads, the intake manifold face on the head will be milled to correctly match the intake manifold angle following angle milling of the combustion face of the head.
No problems with that. I asked the same question. Realize you're not even removing 1/10th of an inch. Doesn't sound like much, huh? ...
No problems with accesory holes lining up with the heads angle milled from AFR. They are taking minimal material from the head in the overall height of the cylinder head.
