Replacing upper inner door seals...?
Old Jan 18, 2009 | 03:31 PM
silver86's Avatar
silver86
Default Replacing upper inner door seals...?
Almost got the door panels ready to go back on after new carpet, new dye, and new upper inner seals. Problem is, I can't get the d@mn staples through the plasting for the seals. I've tried three different staple guns, the last one an electric gun with 14 amps shooting power, and the staples are just bouncing off. I'm using 1/4" 6mm heavy duty staples.
What has anyone used successfully in getting the new seals on?
Thanks!
Old Jan 18, 2009 | 04:13 PM
slickfx3's Avatar
slickfx3
yes you must drill them out and rivet them like you did the outer seals
take your time and it will work and hold.
3/16 irrc
Old Jan 18, 2009 | 05:23 PM
silver86's Avatar
silver86
After I first posted, I ran across an old thread in the General section. It mentioned doing exactly what you said, using rivets. I picked up some ABS/PVC cement to fill in the spaces inbetween, and she seems to be holding so far.
The outer seals, believe or not, don't need replacing. So that's a good thing.
Old Jan 18, 2009 | 05:42 PM
slickfx3's Avatar
slickfx3
better do it while your's at it... what do you think?
Old Jan 18, 2009 | 08:03 PM
guido7834's Avatar
guido7834
I would think "if it ain't broke don't fix it" not that hard to take door panel off if needed in the future.
To Replacing upper inner door seals...?
