my corvette ram air box
Old Jan 19, 2009 | 01:39 PM
pologreen1's Avatar
pologreen1
Default my corvette ram air box
I have not seen many of these, does any one else here have one? Or maybe it is another alternative for some, thought I would share another bad video sorry
Old Jan 19, 2009 | 02:30 PM
NEVRL8T's Avatar
NEVRL8T
I don't have one but if you could light the area you are filming it would really help.
Old Jan 19, 2009 | 03:05 PM
pologreen1's Avatar
pologreen1
yeah I know I will try to redo this, I was in a hurry I was doing something else, and decided to do this, but they turned out horrible
Old Jan 19, 2009 | 04:20 PM
beans-n-icewater's Avatar
beans-n-icewater
Looks good.....
Im in the process of fabricating one myself, using electrical actuators to open and close the license plate cover depending on throttle application
Heres what it looks like so far....
Old Jan 19, 2009 | 04:49 PM
RacerX70CC's Avatar
RacerX70CC
Originally Posted by beans-n-icewater
Looks good.....
Old Jan 19, 2009 | 05:01 PM
pologreen1's Avatar
pologreen1
dang that is cool!
Old Jan 19, 2009 | 05:38 PM
jmrl98's Avatar
jmrl98
Very similar to the TPIS cold air intake - only better quality than the one I sent back. That looked pretty good.
Old Jan 19, 2009 | 06:09 PM
JackDidley's Avatar
JackDidley
Looks good.....
You need to patent that.
Old Jan 19, 2009 | 06:12 PM
whalepirot's Avatar
whalepirot
My Corvette expert told me not to waste my money; that they did little if anything to raise performance. I know all about cold air's effect on power and will probably raise some hackles when I tell you that:
My car spins the 335x17 rear tires in 2nd by mere throttle application. The 409 inhales through a 52mm BBK throttle body, fed by a stock intake that has NOT been cut open or modified in any way. Why on earth would a fairly stock 350 need mods to the intake ducting?
Old Jan 19, 2009 | 06:30 PM
pologreen1's Avatar
pologreen1
I have had this for a while .You cut out the radiator, shroud then the box that has a big scoop built on it goes down through the front, it has a k&N claw in side of it, and yes this one really works, I have had just open or exposed k&N filters before and obviously that does nothing, but when you are driving this is real ram air, and it does help, just like any other car that gets more amounts of air, I think it will work great with my future motor
Old Jan 19, 2009 | 08:16 PM
96 lt-4's Avatar
96 lt-4
I don't think you are getting more hp from the added air unless the stock setup was restricted or not flowing enough air to feed the motor.Now getting more hp from cooler air and/or a direct flowing charge of cooler air that is another story.
To my corvette ram air box
