trans shifter linkage seal
Old Jan 19, 2009 | 06:52 PM
jon0108's Avatar
jon0108
Default trans shifter linkage seal
I had this seal changed about two years ago because it was leaking. Worked fine, but now 2 years later its leaking again. Are there any tips or tricks I should know of before it gets changed again?
86 auto 700R4
Old Feb 25, 2009 | 06:30 PM
jon0108's Avatar
jon0108
Got the seal changed, so far so good. One thing i did notice, the previous seal i used was an ac delco oem. It had a shiny metal outer ring with a rubber insert. The new one i just used is a AGP brand, also with a rubber insert and outer metal ring, but the outer metal ring is wrapped in rubber. Lets see how long this one lasts
