Did I miss something? Just didn't see the "what's your tire pressure thrills?" comment yet
Because instead of the check LTPWS light the Low Tire Pressure warning light would come on. So don't make fun if you don't know.
DUH
90-'92 sensors can be removed
having the car still drivable but '93-'95 is not that easy.
Yes, the car will fall apart without the sensors. HUH :crazy:
Actually it will blow up like a big balloon -- so be really careful :D
:yesnod: The Low Tire Pressure light came on a few times a few months ago, I had the tires filled and no problem since. I'll try clearing the codes and see what happens :cheers:
