Shift Light Wiring?
Old Jan 21, 2002 | 03:39 PM
rcolling's Avatar
rcolling
Default Shift Light Wiring?
I am going to get a shift light for the LT4. Can someone tell me where the wires need to attach to? Are the instructions you get with the light comprehensive enough to let an amateur (me) do this? Any suggestions about where to run the wires through the firewall?
thanks
Old Jan 22, 2002 | 07:20 AM
The Dingo's Avatar
The Dingo
CI 6-7-8-9-10 Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-‘17, '22
Default Re: Shift Light Wiring? (rcolling)
I didn't run any wires into the engine compartment when I installed my Harlan shiftlight.
As per Hutch's website (see explanation below for why I haven't provided a link :rolleyes:), I tapped into the tach lead (white wire off the C100 connector under the dash) for the tach signal. I then used a ground behind the dash and drew my power off one of the fuses in the fusebox (can't recall which one...).
My home computer is out of action at the moment (it's been a week now... :mad) and that is where I had the bookmark for Hutch's website where he had his shiftlight install on his Grand Sport documented quite well. I cannot seem to find the link on the pc I'm using at the moment... (he posts as ZO6VERT now) Perhaps someone else out there can help with the link?
HTH
[Modified by Red 90 L98 Coupe, 5:22 AM 1/22/2002]
Old Jan 22, 2002 | 09:25 AM
-=Jeff=-'s Avatar
-=Jeff=-
Hutch's article
http://www.hashmarks.com/ShiftLight/index.html
Old Jan 22, 2002 | 03:00 PM
rcolling's Avatar
rcolling
thanks,
I think I can do that. Not sure I want to put it in the AC vent, but that lets me know where the wires go.
Exactly what I needed..
I just ordered the Harlan shift light, $50 and it can be set to within 100rpm. The Autometer light with the sending unit, light and pill set was about $170 and could only be set in 200rpm increments.
[Modified by rcolling, 9:52 PM 1/22/2002]
To Shift Light Wiring?
