Side Fender Adjustment
Old Jan 21, 2009 | 04:15 PM
flhtc01's Avatar
flhtc01
Default Side Fender Adjustment
Does anyone know how to adjust the alignment on the side fender? My LH side seems to stick out further than the RH side. I did a search on this subject and did not find anything relevant. I loosened the two upper Torx screws as I see that they have adjustment slots but, was unable to push the upper side in. It appears that just the upper portion is out of alignment. The lower portion is good. The front of the LH side is sticking out approximately 1/2 - 5/8 of an inch which really looks bad compared to the other side. Any ideas?
Old Jan 21, 2009 | 04:25 PM
joecarter85's Avatar
joecarter85
There is a hidden 10mm bolt at the bottom of the side panel, located between the panel and bottom body....You have to loosen this bolt and then you can slide the panel inwards and outwards.
I just did this yesterday when I had to replace my battery.
Just loosen the bolt....do not remove it
Old Jan 21, 2009 | 04:27 PM
flhtc01's Avatar
flhtc01
Joecarter85, Thanks. I will give that a try.
Old Jan 21, 2009 | 07:47 PM
joecarter85
If my description was inadequate, here is a picture showing the location of the bottom panal 10mm bolt location:
Old Jan 22, 2009 | 01:55 AM
pologreen1's Avatar
pologreen1
To Side Fender Adjustment
