SERVICE RIDE CONTROL Light Reset?
Old Jan 23, 2009 | 07:57 AM
BIGJIM13's Avatar
BIGJIM13
Default SERVICE RIDE CONTROL Light Reset?
GUYs
"Service Ride Control" light came on - ran the codes, came up empty.
Anyone know how to reset the light?
Just disconnecting the battery does not work!
Old Jan 23, 2009 | 09:57 AM
toptechx6's Avatar
toptechx6
Originally Posted by BIGJIM13
GUYs
My 93 FSM says to use a Tech 1 or ground pin C in the aldl for two seconds, repeat the procedure two more times for a total of three groundings to clear the codes. Pin out below.
Old Jan 24, 2009 | 12:54 PM
Dads90's Avatar
Dads90
Is something wrong ? Why would the light come on ? My actuators have come loose and that will trip the light. The wire clip may have come out, or the the nut inside on the shock shaft will come loose. Just a thought.
Old Jan 24, 2009 | 01:50 PM
abc 123's Avatar
abc 123
GUYs
If the light comes on and stays on you have a code.
To SERVICE RIDE CONTROL Light Reset?
