Worn Suspension Bushings
Old Jan 21, 2002 | 08:27 PM
KYVette90's Avatar
KYVette90
Default Worn Suspension Bushings
Will worn suspension bushings, mainly front sway bar bushings, cause premature tire wear? The outside edge of my front driver side tire is wearing faster than the rest of the tire.
Old Jan 21, 2002 | 09:27 PM
mash557's Avatar
mash557
Default Re: Worn Suspension Bushings (KYVette90)
wouldn't think sway bar bushings would cause tire wear. I would look at ball joints and the alignment first.
Old Jan 22, 2002 | 12:03 AM
h rocks's Avatar
h rocks
Check your alignment. Sounds like you may have too much toe in on that side, along with some positive camber.
Old Jan 22, 2002 | 12:08 AM
vader86's Avatar
vader86
Default Re: Worn Suspension Bushings (h rocks)
bad alignment, tie rod may need replacing
Old Jan 22, 2002 | 10:44 AM
Goody's Avatar
Goody
Default Re: Worn Suspension Bushings (vader86)
Nope, not swaybar related. Think ball joint or tie rods.
Old Jan 22, 2002 | 07:53 PM
KYVette90's Avatar
KYVette90
Default Re: Worn Suspension Bushings (Goody)
Thanks guys. My dad had a new steering rack installed for me while I was in the Persian gulf. I think the guy that did it messed up the alignment job. Thats why I don't let anybody work on it but myself. :cheers:
To Worn Suspension Bushings
