Quick engine question...
Old Jan 21, 2002 | 11:59 PM
GlockLT4's Avatar
GlockLT4
Default Quick engine question...
Define "Comp Height" ... in relation to the specs of pistons.
The only thing I can come up with is the height of the piston at which it has reached it's maximum compression ... ie the TDC position of the piston. Anyone know?
[Modified by Glock'94, 10:04 PM 1/21/2002]
Old Jan 22, 2002 | 12:20 AM
bogus's Avatar
bogus
Default Re: Quick engine question... (Glock'94)
:confused:
never heard that term before...
Old Jan 22, 2002 | 12:24 AM
GlockLT4's Avatar
GlockLT4
Default Re: Quick engine question... (bogus)
Old Jan 22, 2002 | 12:51 AM
jvesalga's Avatar
jvesalga
Comp Height is called Compression Height. The Compression Height of a piston is the distance from the center of the piston pin hole to the deck or top of the piston (excluding dome if any).
Here is a diagram from my good friends at Ross:
http://www.rosspistons.com/custom/co...ionheight.php3
Old Jan 22, 2002 | 12:55 AM
jvesalga's Avatar
jvesalga
OH yes and in general you are looking for "normal" or zero. Less will mean less compression. More can mean a piston hitting the flat porion of the head unless the shop you have taken your block to has checked it thoroughly...
Old Jan 22, 2002 | 01:14 AM
GlockLT4's Avatar
GlockLT4
Default Re: Quick engine question... (jvesalga)
Thanx ... just talked to a friend who said the same.. :cheers:
To Quick engine question...
