High idle after driving and code 33
I joined to post these problems:
1. At startup idle is fine, during and after a drive idle slowly creeps up to 2300 RPM in neutral or park. Shut down and restart, idle is back to normal? While driving, engine occasionally bogs and when braking increases idle which doesn't come back down.
2. I have a persistant code 33, steps I've taken below.
PO had removed the SES bulb which has been throwing a code 33 since day one, within 5 seconds of start up. It never goes away and I am disconnecting the neg battery terminal to clear codes.
Tried a good MAF from a reputable vette shop and same code.
Cleaned TB, AIC, reset min. idle and TPS to spec.
New fuel filter and PCV after running two cans of 44k.
New MAF relays (both)
New safety neutral swith (back up lights weren't working)
Voltage to MAF checks out.
Ohm reading on injectors all at 63
The only MOD is aftermarket Borla exhaust.
What am I missing?
Thanks!
I drove it again earlier today and same problem with the idle going higher and higher! Shut it off and idle reset to normal.
Thanks,
Mark
.70 so I did the reset on the Min. idle and got the TPS back to .54. Still throwing code 33 and having the idle issue but maybe the TPS is the problem.
I was thinking O2 sensor or coolant temp. sensor. By the way I did swap the 180 thermostat for a 160, maybe that has something to do with it?
I'm not sure but I think for a daily driver, 160 degrees is too cold. The ECU may not go into closed loop for a long time and may open again if you are cruising at freeway speeds. I used to have a 180 degree 'stat which would give a temperature indication of 178 or so on the freeway. I swapped it for a stock 195 and flushed the system really thoroughly. It runs great.
Turns out the IAC was bad which, when replaced, fixed the bogging and idle issues. The codee 33 was being caused by bad contact in the MAF sensor harness.
Pulling of the MAF sensor connector I noticed that 3 of the female connections had been spread out fairly wide, so I pinched them down, reconnected, and the code 33 went away.
All is well now except I'm curious why my oil preassure is reading zero at idle, goes higher while under load.
Thanks again for the help!
Mark in Virginia
