Spark Plug Wire Suggestions
Old Jan 27, 2009 | 09:18 PM
conrarn's Avatar
conrarn
Default Spark Plug Wire Suggestions
I was going to replace the spark plug wires in my 1994 C4 since they are 15 years old. The car is running OK but I thought it might be wise. I am not looking for super performance, just basic operation. Any suggestion on which type of wires to get? If you can, please provide a link. Also, I notice the spark plug wire retainers were very brittle so I was going to get new ones. Suggestion on those would be appreciated.
Old Jan 27, 2009 | 10:40 PM
STL94LT1's Avatar
STL94LT1
Taylor Spiro Pro 7mm wires are a nice replacement set. Check Summit or Jegs.
Old Jan 28, 2009 | 08:03 AM
runner140*'s Avatar
runner140*
Old Jan 29, 2009 | 09:10 PM
conrarn's Avatar
conrarn
This is all I found so far. You guys have some links to share?
Jegs
http://www.jegs.com/webapp/wcs/store...192&Ne=3003116
Zip Corvette
http://www.zip-products.com/Zip/prod...E3B42FAA2ABCE1
Still need to find the find the retainers to separate the wires.
Old Jan 29, 2009 | 10:24 PM
STL94LT1's Avatar
STL94LT1
The Zip wires look like the ones I've been running for the last 6 or 7 years. I'll get you a part number tomorrow.
Old Jan 29, 2009 | 10:26 PM
5POINT7's Avatar
5POINT7
curious for the part number as well. Id like to change my plugs someday soon, might as well do my 14 year old wires as well. thanks!
Old Jan 30, 2009 | 03:20 AM
RedDwarf's Avatar
RedDwarf
The MSD 8.8 Super Conductors are the best you can buy...I've actually checked the ohm reading on them and several others I had laying around and they beat the others by miles..The nice thing is you can get them in black if you don't like the red.
Old Jan 30, 2009 | 08:38 AM
5abivt's Avatar
5abivt
I've tried them all on the vette and 3 brands on the dd. Msd, Taylor, accel, etc. Magnecor hands down are the best quality. Can't say they work 'better' but on my oldsmobile that has a transverse v-8 the wires closest to the firewall have lasted 5 years now with magnecors. the Taylormade spiropro and msd died within a year and a half from the heat.
Old Jan 30, 2009 | 09:42 AM
conrarn's Avatar
conrarn
They look pretty good. They have 7.0, 8.0, and 8.5 mm. The 8.5 mm looks like their best product which would cost $168.00.
Here is their link and catalog.
http://www.magnecor.com/
http://www.magnecor.com/magnecor1/files/catalog.pdf
Old Jan 30, 2009 | 10:51 AM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
Not sure about which wires -- but one thought is if the OEM wires have lasted 15 years and the car is still running ok, I'd go with the OEM's again.
Also, be careful about thicker wires, they might not fit in the tight passageway around/behind the alternator. Also, the thicker wires might not fit in the OEM wire retainers.
FYI, some have used/recommended the GM Performance wires, checkout the relatively new website gmperformanceparts.com or many of the forum sponsors (e.g. Gene). Also, regarding the wire retainers, again any of the sponsors -- got mine at ecklers.com.
Regarding the spark plugs, I changed the ones in our 94 in 2007 and opted to NOT use the AC/Delcos (platinum puck problem -- 3 were missing). I instead went with the NGK Iridium TR55ix (good reports on them, no puck problems, and Iridium is very high mileage and high-quality, so will not need to do in a long while. Performance is good and mileage great. Remember to put a small dab of anti-sieze on the plugs threads and use a torque wrench to assure proper install (I found 3 plugs loose, so obviously the previous 'mechanic' did not!).
FYI, I wrote-up a post on changing the plugs, do an advanced search for my id and 'spark', it should really help you do yours.
Old Jan 30, 2009 | 11:26 AM
STL94LT1's Avatar
STL94LT1
Taylor Spiro Pro 7mm part # 74225.
Old Jan 30, 2009 | 12:56 PM
DCP's Avatar
DCP
Sent you a PM.
David
Old Jan 30, 2009 | 03:17 PM
NEVRL8T's Avatar
NEVRL8T
Originally Posted by RedDwarf
The MSD 8.8 Super Conductors. The nice thing is you can get them in black if you don't like the red.
I have black.
Old Jan 30, 2009 | 03:56 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Is it really worth twice the cost for MSD wires I think not. Any quality wire will do the same thing deliver voltage even OEM. Has anyone got something to justify the MSD price?
Old Jan 31, 2009 | 01:18 AM
Arkybill's Avatar
Arkybill
Last summer I replaced the optispark(looked ok on the outside, but not so good inside). At the same time I replaced the wires and plugs, since the car had 101K on it and ran ok (well, until it quit-problem was the ign. module) I went back with OEM plugs and wires, everything fit just fine and runs like a haint. I figured if the OEM stuff lasted 100K, it'd be ok to use again.
I'm happy with the OEM stuff.
bill
Old Jan 31, 2009 | 12:26 PM
conrarn's Avatar
conrarn
I was going to get OEM everything but it looks like a tough job to replace those guys. Everything is running fine right now and the wires look like they are good condition, even if they are 15 years old with 60K+ miles. I don't know the previous owners to ask them if they were ever replaced before.
Old Mar 17, 2009 | 11:06 PM
conrarn's Avatar
conrarn
Well, I finally got the new plugs and wires installed. The car runs remarkably better. I ended up using the OEM wires and plugs.
Old Mar 18, 2009 | 12:37 AM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Buy a set which all eight of them have a 90 degree boot for the spark plugs. This will help the installation for #6 and #8.
Old Mar 18, 2009 | 08:40 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
I went with NAPA/Belden Super Blue 7 mm Premium Ignition Wires. O.E.M. length and fitment, plus you get an additional discount at the store with your AAA auto card, too.
For the O.E.M. Packard looms and wire holders, I ordered mine online from Mid-America Motorworks (MAM).
http://www.mamotorworks.com/corvette...20plug%20looms
Don't forget the anti-seize compound for the spark plugs (aluminum heads) if you're going to swap those out, too. No better time to do it. I like NGK Platinum Plus in the TR-55 flavor.
To Spark Plug Wire Suggestions
