12V for Electric Water Pump
Old Jan 29, 2009 | 10:21 PM
matt_jahn's Avatar
matt_jahn
Default 12V for Electric Water Pump
Im installing the summit electric water pump that comes with the wiring and fuse. and it saids to go to a 12v source. since I dont yet have a DVOM could someone tell me a good wire to use. giving 12v when the ign is on or running?
thanks
PS i tried searching but if there is a thread i looked over a link would be fine
Old Jan 29, 2009 | 11:27 PM
reoch999's Avatar
reoch999
Any Auto Zone or Advance Auto or Napa or other parts store should sell a 12V test light for under $10. It's a handy tool to have around because the test probe is thin and sharp enough to push through the insulator and hit the conductor without stripping it back. It's simple to use too, clip the long wire to ground and test away. I definately prefer it over a DVM for finding 12 volts in cars.
Old Jan 29, 2009 | 11:38 PM
rodj's Avatar
rodj
Most seem too get theirs from the fan supply
Old Jan 30, 2009 | 11:08 AM
byedan's Avatar
byedan
you want to use a relay, i took the power for the fan from the battery and grounded at the frame. i ran my relay off of the fan relay since it is hot when the switch is on. you will also need to upgrade your fan fuse from 7.5 amps to 10 or maybe from 5 to 10. all grounds go the frame at the horn on my car pretty simple really. The wire you are looking for at the fan realy is pink and on the drivers side of the radiator
Old Jan 30, 2009 | 11:32 AM
STL94LT1's Avatar
STL94LT1
I used the little red box next to the battery for the relay's power.
Old Jan 30, 2009 | 02:19 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Use the fan relay for the SIGNAL
use that signal to trigger a RELAY
use the relay to get power from the CIRCUIT BUS
the circuit bus has a tie in to the BATTERY
To 12V for Electric Water Pump
