How does one turn off Lockup?
Old Jan 30, 2009 | 05:41 PM
freedog81's Avatar
freedog81
Default How does one turn off Lockup?
The lockup on my tq converter is slipping how can I turn it off until I have time to fix it?... I know it will hurt mileage and more heat etc I just need it off.
thanks
Old Jan 30, 2009 | 06:38 PM
Muffin's Avatar
Muffin
Unplug it. Plug is located on the driver side of the transmission in the middle. Plug at the end is speed sensor.
Old Jan 30, 2009 | 07:00 PM
molested84's Avatar
molested84
Couldn't you just place the transmission selection lever in "Drive" instead of "OverDrive"?
Old Jan 30, 2009 | 07:09 PM
TA's Avatar
TA
I don't think that will work. At the track I run my car in "Drive" and the converter still locks up.
Old Jan 30, 2009 | 08:10 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Won't work with a 700R/4; on the dyno in 3rd gear the TCC locked up at ~125mph so hard the operator thought it made a gear change...
Old Jan 30, 2009 | 08:13 PM
Iroc57's Avatar
Iroc57
It will lock in drive as well
Old Jan 30, 2009 | 08:25 PM
383vett's Avatar
383vett
Intercept the tcc wire between the ecm and the transmission harness (I think it's a white wire). I have mine connected to a switch on the console and lock up the converter manually. You can just cut the wire and later splice it together.
Old Jan 30, 2009 | 09:33 PM
TX VET MAN's Avatar
TX VET MAN
When you say the converter "locks up"...does that mean it shifts into overdrive?
Old Jan 30, 2009 | 10:40 PM
Aardwolf's Avatar
Aardwolf
Slipping? At a cruise around say 55 MPH just press the brake lightly and don't move the gas, your RPM should go up 200. Very easy to check.
Old Jan 30, 2009 | 11:31 PM
rodj's Avatar
rodj
No ; lockup is when the clutch in the convertor locks , not when it shifts into 4th (O/d ).
Old Jan 30, 2009 | 11:33 PM
rodj's Avatar
rodj
One of the 2 pairs of wires on the brake pedal switch is for the TCC .
Disconnect one wire; if your stoplamps don't work anymore you have the wrong one.
Old Jan 31, 2009 | 12:55 AM
Weav's Vet's Avatar
Weav's Vet
Not meaning to hijack but......what would cause a converter to lock, unlock and then not lock again in normal driving on my '96? Stop and cut the car off and it works fine.
Old Jan 31, 2009 | 04:02 AM
freedog81's Avatar
freedog81
No problem on the hijacking... I think it is worth it for the additional knowledge on the transmission. I will try the brake switch unplugging first and if that dosent work then I will unplug it at the transmission.
Old Jan 31, 2009 | 07:24 AM
rodj's Avatar
rodj
It will work if you pull the correct one TCC signal runs from ECM through switch to trans.
Switch is normally closed letting convertor lock up until you brake
Old Jan 31, 2009 | 07:47 AM
TA's Avatar
TA
This will work, although you'll also lose your speedometer and odometer when unplugged.
Old Jan 31, 2009 | 08:00 AM
Muffin's Avatar
Muffin
There are two plug-ins on the 700R4. One at the tailstock area is speed related.One in the center,more or less, is TCC lock up and 4th gear signal. Can be bypassed by cutting wires but why cut anything if the repair isn't going to take forever?
Old Jan 31, 2009 | 09:59 AM
freedog81's Avatar
freedog81
I want to avoid cutting any wires.. the car is my dd and I just don't have the time right now to deal with it and if it will hold on for about a week I should be caught up enough to get to it.
thanks everyone
To How does one turn off Lockup?
