Replacing Opti
Old Jan 31, 2009 | 02:47 PM
arbee's Avatar
arbee
Default Replacing Opti
Hope someone can help me on this. I have a 92 coupe that had it's water pump spring a leak just at season's end. I descided to change the opti at the same time as the water pump as the car had 115,000 on the clock when I bought it. I just received the parts and noticed that the spline on the new opti seems to have one or two of the grooves filled in with metal. Is this the way it is supposed to be or is the spline supposed to be all the way around. I found lots of info about removing the dampener and such when I searched but could not find this answer. Thanks for any assistance.
Old Jan 31, 2009 | 03:33 PM
toptechx6's Avatar
toptechx6
If the spline was the same all the way round how could it be indexed?
Old Jan 31, 2009 | 03:34 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
the spline on the older ones are keyed, is that what your seeing?
BTW You can vent the older ones
Old Jan 31, 2009 | 03:44 PM
joecarter85's Avatar
joecarter85
Yes, that's the way it is supposed to be. The Opti will only fit in one way.
Old Jan 31, 2009 | 07:12 PM
arbee's Avatar
arbee
Thanks for the help, answers my concerns perfectly!
To Replacing Opti
