Make your Own!
These are for my 85 so adapt as you see fit
Black out Backing Lights- Remove backing Lights Installed Low voltagedriving Lights via mounting to Lisc plate bracket
Then Cut Plexigass to cover all of the opening (pnumatic cutting wheel) sand the edges, Tint via film (the lighter the better), allow to dry. Put trim on edges. Next FILM SIDE UP Slowly drill a hole to match your Lisc plate bolt holes. and POW your done. add smoked Lisc plate cover.
Dash Panel- Took out my bread box and basicaly did the same thing.
Cut Plexiglass to fit, Tinted (as dark as i could find), Slowly drill your mounting holes (i opted not to cut in the vent), add tripm (top and bottom only) , used a Peel and stick bumper emblem.
I will have Pics up by the weekend. It was all really easy and cost like 15 bucks.
