What else typicaly goes with hotcam
Old Feb 2, 2009 | 07:51 PM
chadihrig121's Avatar
chadihrig121
Default What else typicaly goes with hotcam
Im doing a hotcam on my 96 lt4. Im going with long tubes. Also the car has corsa exhaust and K&N air filter. Will this setup need to be dyno tuned.? what are some other typical mods that are a "might as well" that go along with a hotcam that I could squeeze a little more power out of? what can I expect for horsepower? 1/4 mile times?
Old Feb 2, 2009 | 10:56 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
electric WP for drag and autocrossing
Get a new stocker if your road racing
How's the opti? At least put a new cap & rotor on it.
Stick or auto?
If auto then a coverter
gears for a stick
Old Feb 3, 2009 | 05:54 AM
James93LT1's Avatar
James93LT1
Veteran: National Guard
Take a look at one of Forum members site.
http://www.wku.edu/~nathan.plemons/index.html
Old Feb 3, 2009 | 02:50 PM
GM_96LT4's Avatar
GM_96LT4
If you are going to spend the time or money getting to the hotcam; I would suggest a set of heads as well.
A lot of different options out there to suit your budget.
just my 0.02 cents.
glenn
Old Feb 3, 2009 | 03:39 PM
RacerX70CC's Avatar
RacerX70CC
Stick or auto?
gears for a stick
electric water pump is a good mod.. that frees you from having to use the LT style timing chain setup, plus properly wired, you can use it to cool the engine between rounds at the track
Old Feb 4, 2009 | 02:03 AM
ZD1's Avatar
ZD1
1.6 or 1.65 roller tip/trunion rockers are a must do
stiffer (better) or cyro'd springs
other induction stuff like TB and temp relocation
Dyno (or more appropiate road tuning) would be on the hairy edge with this setup...which is why you move the IAT sensor away from the engine.
Old Feb 4, 2009 | 04:06 AM
Swedish Hot Rod's Avatar
Swedish Hot Rod
Stick or auto?
All LT4´s came with a stick, but then of course some auto LT1´s could have been modified to LT4.
I think LT4`s has 1.6 rollers.
Old Feb 4, 2009 | 11:10 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
What goes with a HOTCAM?......
For me, it was comments about how newer, better cam profiles exist. Consider other options if/when replacing cam, heads, etc....
To What else typicaly goes with hotcam
