lt's on a 91
Old Feb 5, 2009 | 10:00 AM
DeBaGo's Avatar
DeBaGo
Default lt's on a 91
Looking to pick up a 91 in a few weeks (fingers crossed). I been looking around online and looks like I can get some headers pretty reasonably. Now most say 87-91, now I know the 91 body is a little different, but will the same headers fit? I know they are the same L98 as far as I know.
How easy is the install? I know the F-body can be a nightmare. I also want to run true duals. Is it best to have an h or x pipe in place?\
Also, what kind of gains have you guys seen with exhausts? Any seat of the pants difference?
Thanks guys! Hope to be back in a vette soon
I miss the wave......
Old Feb 5, 2009 | 10:07 AM
95BlueBomber's Avatar
95BlueBomber
As far as the headers, yes they should fit fine. I am not real sure on the install, are you looking at long tubes or shorties?
I always go X-Pipe, my thought has always been the air crossing each other will almost cause like a vacuum right there and help flow the exhaust out. The H-Pipe never seemed good to me, I would think there would be minimal exhaust go through the H because of the vacuum like pressure going across the opening on both sides.
just my .02, get the X and longtubes
Old Feb 5, 2009 | 10:13 AM
DeBaGo's Avatar
DeBaGo
I'd never waste time on shorties. Yeah I heard that the cross pipe would help some, just wanted to double check. Also if I get one with EGR and O2 is there a place where they can delete them from the computer? Or can have it done locally by a tuner? No emissions here so I dont care about that.
Thanks again guys
Old Feb 5, 2009 | 10:28 AM
95BlueBomber
I took mine off my 88 and got the air pump delete kit from a vendor. I believe you can delete it all with no problems. I cant remember if I left the EGR sensor plugged in and attached it to the firewall or not. I think Breathless performance is where I got that delete kit. It cleans the engine bay up a lot! It also will free up some power.
BTW nice lookin ride!
Old Feb 5, 2009 | 10:30 AM
twin540's Avatar
twin540
I have a 91 and I installed the headman elites without the air/egr acc. Fairly easy install. I also installed a 3-wire o2 at the bung. As far as performance ,I can't really tell you I did a whole engine, exhaust with true dual and x-pipe all at the same time..You're not going to have any problems with the a/c bracket, I don't know if you get it with the air/egr acc.
Old Feb 5, 2009 | 10:40 AM
DeBaGo's Avatar
DeBaGo
Thanks, but thats the my old 91 I sold 2 years ago
The ones I am looking at are both 91 and both bright red as well. I need to tint them like that one though. Even the whole windshield was done!
I love white vettes, but hey they never wrote a song about a little WHITE corvette now did they
Old Feb 5, 2009 | 10:59 AM
bwv505's Avatar
bwv505
This is kinda off topic, but I am in Jacksonville also and just picked up a 91 coupe last weekend. Mine needs work though, hopefully get a wave to you soon though..
Old Feb 5, 2009 | 11:15 AM
95BlueBomber
All Corvettes are RED!
Old Feb 5, 2009 | 11:22 AM
Iroc57's Avatar
Iroc57
Thanks again guys
EGR is no biggie but If you are saying that you would not run an O2 sensor I think that your EFI may have something to say about that. If I misread I apologize
Old Feb 5, 2009 | 11:38 AM
DeBaGo's Avatar
DeBaGo
Thats exactly what I want. I have had some h/c lt1/4 cars and my trans am had the egr and o2 deleted from the computer via a mail order tune. I didnt know if L98 had similiar support out there.
bwv505, what part of town? I'm on southside/baymeadows. My buddy has a MINT 95 white with red leather, and that kind of got me bitten by the vette bug again. Now that the family has a big 3 row suv to haul everyone around, the wife didnt care what I got to drive...WOO HOO! I hope the one I want is still available in another couple weeks when I get my taxes.
Old Feb 5, 2009 | 12:13 PM
383vett's Avatar
383vett
Maybe with your trans am they deleted the REAR O2 sensors. If your sensors were deleted in the 91, your car would run only in open loop and I'm not sure that's what you want.
Old Feb 5, 2009 | 01:54 PM
DeBaGo's Avatar
DeBaGo
yeah the rear o2 delete so I could get the off road header (read: cheaper)
Old Feb 5, 2009 | 02:01 PM
95BlueBomber
on my 88 I deleted the cat and you just need to put the 02 back in the pipe. Just have a bung welded in and put it back. The rear 02 does nothing but keep the cat in check. As long as its reading its fine, it doesnt change fueling to the ecm.
95BlueBomber
Or I guess you could get a simulator to delete it all together.
Old Feb 5, 2009 | 02:09 PM
bwv505's Avatar
bwv505
I am in the Arlington area, it's good to hear of local people still into the C4, you see tons of C5, C6 cars but not alot of nice C4's.... We need to get them back out there!
Old Feb 5, 2009 | 02:35 PM
DeBaGo's Avatar
DeBaGo
i just moved from Arlington, there was always 1 rough looking one around. I never see c4's, there are several c5s at work though.
So just to be clear on the exhaust. I want longtubes, straight back, no cats, maybe little bullet muffler...maybe, then tips on the rear. Now with this on an L98, i dont need to worry about the rear O2? Or I just need to get an extension and have a bung welded in?
Old Feb 5, 2009 | 05:20 PM
Iroc57's Avatar
Iroc57
I don't recall a rear O2 sensor on my 91' or in the FSM. Someone will correct me here if I am wrong but I think that you will need to weld in the bung for the O2 sensor on the drivers side header.
To lt's on a 91
Old Feb 5, 2009 | 05:44 PM
DeBaGo's Avatar
DeBaGo
Like I said it was on a LT car. My old 91 vette, was stock except for muffler deletes. So I'm just trying to clear up whats needed to run true duals? Just bolt in and go? Because I found some painted headers new for under 200 for a 91, but they have no emissions stuff on them.
Old Feb 5, 2009 | 06:09 PM
Iroc57's Avatar
Iroc57
I will let someone that actually has a small block chime here
There is a point where you have to use a heated sensor and I am not sure how far back that is.
Heck, I can't even spell EFI
Old Feb 6, 2009 | 05:48 AM
Yorcci's Avatar
Yorcci
No rear O2's with '91. There's just one located at the driver's side exhaust. See the picture below, the O2 sensor is hiding behind the bar, just follow the purple wire:
You can remove the EGR diagnostics from the chip, but the chip needs to be replaced or bypassed partially. This is, what we did with my '91:
Had the EGR diagnostics disabled (and fans on/off temperatures changed):
And the new chip will be installed so that it only bypasses part of the original chip functions, the original chip still operates everything except engine diagnostics:
Then the new chip was burned and pressed on its place:
The original chip is still with at all times, if the burned chip should somehow act faulty:
