Torque converter lockup ??
Old Feb 5, 2009 | 01:05 PM
MMOCguy's Avatar
MMOCguy
Default Torque converter lockup ??
Hi all.
I have a factory stock 1993 C-4 with a 4L60 transmission. My torque converter doesn't seem to locking as it should but i'm not sure.
Does anyone know the specs for TQ lockup? At what speed minimum, which gears, etc.?
I've done the preliminary tests and all seems to be well with the external wiring and switches. I've also temporarily wired in a switch between the A & F terminals of the ALDL plug. That switch does not seem to effect the TQ no matter which position I put it in.
Thanks for any responses.
Norm.
Old Feb 6, 2009 | 09:13 PM
H Watkins's Avatar
H Watkins
St. Jude Donor '15-'16, '21,'24
Old Feb 6, 2009 | 09:56 PM
rodj's Avatar
rodj
Usual quicky test is to run at cruise speed when convertor "should" be locked and touch brake.
Revs should rise if convertor unlocks
Old Feb 7, 2009 | 12:01 AM
MMOCguy's Avatar
MMOCguy
Rod,
Thanks for your input. I am aware of that test and, yes it does lockup sometimes. The problem is that I'm not sure under what conditions it is supposed to lockup so I can't tell if it is locking when it is supposed to or not.
What I really need, if anyone has the answer, is the answer to these two questions:
At what minimum speed is it supposed to lockup?
In what gears is it supposed to lockup? 3rd & 4th, just 4th, etc.?
I am aware that it shouldn't lockup under hard acceleration or below a certain speed. Also, as I said, I did wire a temporary switch between the "A" and "F" terminals of ALDL connector. With the switch in "On" position the torque converter should be locked up manually however that doesn't seem to work (At least not at speeds up to 55 MPH).
Thanks all in advance for any thoughts.
Norm.
Old Feb 7, 2009 | 01:26 AM
rodj's Avatar
rodj
Notes from another site.
This A/F switch will override the TC lock signal from the ECM. Except for first gear. So if you engage the switch from a standstill, the TC will lock once the 1-2 shift engages. Then each upshift of the trans will happen with a locked TC.
Old Feb 7, 2009 | 01:46 AM
rodj's Avatar
rodj
I downloaded and run a stock bin for a 93 in Tunerpro.
TCC settings are related to throttle %TPS v mph ;
but 44 mph appears to be the TCC lockup point
There are lock / unlock settings for both 3rd and 4th gear.
Old Feb 7, 2009 | 02:36 AM
MMOCguy's Avatar
MMOCguy
Rod.
Thanks that's the kind of info I'm looking for.
I hate to sound stupid here but, what is BIN? Also, Tuner-Pro works with OBD1 ??
Thanks again for your advice.
Norm.
Old Feb 7, 2009 | 03:04 AM
rodj's Avatar
rodj
BIN is the code that is programmed in the ECM containing all the engine management specs.
Old Feb 7, 2009 | 12:49 PM
MMOCguy's Avatar
MMOCguy
One more question. Did you download from Tuner-Pro?
Thanks,
Norm.
Old Feb 7, 2009 | 01:07 PM
janarvae's Avatar
janarvae
Rod.
Norm.
TunerPro works with OBDI. You have to download it from tunerpro (for free, but he asks for a donation if you like it) and buy yourself an ALDL USB cable to connect your laptop. I got my cable HERE - make sure you install the driver that comes on the CD with the cable first and then program TunerPro to look at the correct port the USB is plugged into. Then you can start datalogging (after setting up TunerPro, of course).
-Jonathan
Old Feb 7, 2009 | 05:38 PM
rodj's Avatar
rodj
Tuner-Pro is the aftermarket program that lets you datalog or adjust the tune on your ECM (with the right equipment)
The original codes (BINS) are available free from many sites.
Even if you don't connect to car ,you can do what I did for you and just open the bin to see the factory settings.
Old Feb 7, 2009 | 05:47 PM
MMOCguy's Avatar
MMOCguy
Rod and Jonathan.
Thank you both very much. You both have been a *BIG* help and the information is exactly what I needed. I hope I can reciprocate one of these days.
Norm.
To Torque converter lockup ??
