Superram lexan lid
Old Feb 7, 2009 | 02:35 AM
RatC4's Avatar
RatC4
Default Superram lexan lid
Has anybody fabricated a Superram top from a sheet of polycarbonate? Not for any performance reason but just for cosmetics. I'm thinking about doing it. It's possible that it would help insulate the manifold from some of the engine heat.
Old Feb 7, 2009 | 02:43 AM
slickfx3's Avatar
slickfx3
go ahead and let us know...
Old Feb 7, 2009 | 02:52 AM
RatC4's Avatar
RatC4
I think I'll take a trip to Tap plastics and see if the have and scrap 3/8 inch sheets.
Old Feb 7, 2009 | 03:15 AM
slickfx3's Avatar
slickfx3
then you'll have to paint a mural on the insides of the box, so it could look like a tower desktop with the same treatment.
cause not doing anything, is just showing factory gasket matching,
i saw agent 86's insides and they were ported, clould they not siameise the plenum and semi saimeise and blade the runners, i guess that wouldraise the rpm band...
Old Feb 7, 2009 | 08:57 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
Why? It's just going to get covered with black residue from reversion.
Old Feb 7, 2009 | 09:30 AM
Aurora40's Avatar
Aurora40
Yeah, I think it would start to look pretty gross.
Old Feb 7, 2009 | 09:38 AM
Aardwolf's Avatar
Aardwolf
Good idea, the lid is grossly heavy.
Old Feb 7, 2009 | 11:07 AM
pologreen1's Avatar
pologreen1
It is very heavy, and also on some other forums, in the past I think people have siamesed the rSR with out much or any gain.
Old Feb 7, 2009 | 12:35 PM
Slalom4me's Avatar
Slalom4me
SuperRam Lexan lid
Has anybody fabricated a SuperRam top from a sheet of polycarbonate?
Not for any performance reason, but just for cosmetics.
With the exception of PEEK and Teflon (neither of which are transparent,
TTBoMK) the rest of the substances listed in the following chart have
a "Continuous Service Temperature - in Air (max.)" range of 160-221ºF.
Plastics Comparison Table.
Machinist-Materials.com
As a substitute for the aluminum SR lid, my vote is that choices from
the chart other than PEEK/Teflon would be fine for static display, not fine
for use in service.
I am unaware of what material GM uses for the ZR1's clear hood bubble.
Old Feb 7, 2009 | 12:40 PM
Slalom4me's Avatar
Slalom4me
Oops.
Correction - I failed to scroll far enough to the right of the chart
I see that Polycarbonate (aka: Lexan®, Hyzod®) is rated to
475ºF.
This service ceiling might work ...
Old Feb 7, 2009 | 01:09 PM
Slalom4me's Avatar
Slalom4me
Grossly heavy?
It is cast aluminum - reasonably light amongst the cost-effective
material choices available at the time. The optional 'billet' lid
appeared to be thicker and did not have the cast ribs.
The SR lid spans a large area of the plenum without any support
and needs to be able to withstand resonant waves.
Density Lbs/cubic In
  • .043 - Polycarbonate (Lexan)
  • .098 - Aluminum
Although the polycarbonate is less than half the density of aluminum
my vote is that some other criteria should be evaluated before making
an exact dimensional copy of the aluminum piece.
Old Feb 7, 2009 | 04:02 PM
TA's Avatar
TA
There's nothing in there I'm really interested in seeing.
Old Feb 7, 2009 | 04:07 PM
slickfx3's Avatar
slickfx3
lol
Old Feb 7, 2009 | 04:09 PM
cv67's Avatar
cv67
St. Jude Donor '05
Put a small animal in there.
Old Feb 7, 2009 | 04:12 PM
LD85's Avatar
LD85
Once Polycarb fogs over due to the fuel vapors, you will see nothing any way,
but if you are really bored, You would have to use Polycarb at least 5/16 or probably 3/8 thick to keep the mount holes from cracking out to the edge of the lid when you tighten it down.
You would be better off to mill out a 6"x6" or 8"x8" hole in the middle and bolt the clear piece to a spot in the center of the lid,
Old Feb 7, 2009 | 04:38 PM
Aardwolf's Avatar
Aardwolf
Originally Posted by Slalom4me
Grossly heavy?
Mine didn't come with the billet lid. I wonder if a brass insert would help for the bolt holes and cracking.
Old Feb 7, 2009 | 05:26 PM
pologreen1's Avatar
pologreen1
mine weighs a lot also, even though it looks really cool with the polished mirror finish.
To Superram lexan lid
Old Feb 8, 2009 | 10:28 PM
Slalom4me's Avatar
Slalom4me
any way,
But if you are really bored, you would have to use Polycarb at least
LD85 raises a good point ...
Although Lexan Corrugated sheet is unharmed by many
chemical substances, it is important to avoid contact with
adhesives, paints or solvents which are incompatible with
polycarbonate. Chemicals to avoid include: benzene, gasoline,
acetone, and carbontetrachloride, among others.
I know that products like acetone (used in nail-polish remover) are
fast-acting when it comes to attacking polycarbonates. Gasoline
might take longer to cause it to haze over. Perhaps get sample
material and smear gasoline on in order to test first-hand before
putting any work into fabrication.
Regarding the prospect of the fasteners causing stress cracks to
radiate out from bolt holes in the Lexan. One possible solution
might be to design for inserts to prevent overtightening - pieces
of brass or steel tubing cut to length to fit inside the bolt holes
in the Lexan.
Incidently, the current issue of Popular Hot Rodding has a feature
car with clear top valve covers. IIRC, it is a 64-67 Chevelle with
black-on-red two-tone paint. (This feature does not appear on the
PHR website at the moment but the magazine cover has PHR's '75
Laguna being prepped for paint and other articles in the issue include
one about CPP tie rod arm adjuster sleeves for a blue '68 Chevelle.)
Old Feb 8, 2009 | 10:35 PM
Slalom4me's Avatar
Slalom4me
Oops.
Sorry, Aardwolf. I had not noticed that you had already suggested
this.
I agree with you that something along this line would improve or
eliminate cracking. Unless the material was costly, I would consider
trying simple drilled holes first to see whether there was an issue.
Old Feb 8, 2009 | 11:42 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
you can do it, LSX intakes are plastic
You need to look at the material properties.
The reason the lid is thick is because of the loads
When the throttle is shut there's a vacuum trying to pull it down.
Load = length X width X psi vacuum
