aluminum pulleys?
Old Feb 8, 2009 | 12:33 PM
ladystoy69's Avatar
ladystoy69
Default aluminum pulleys?
early c4
anyone running aluminum pulleys? like march, zoops, summit.
what is the deal with the pulleys for corvette costing so much more than others? (corvette tax i guess)
anyone have any experiance or advice on using pulleys from a different application, lets say like camaro pulleys?
Old Feb 8, 2009 | 01:50 PM
pologreen1's Avatar
pologreen1
Old Feb 8, 2009 | 02:03 PM
KoKane's Avatar
KoKane
Think one of the reasons is a camaro crank pulley is just that. A pulley. On a vette, a crank pulley is a pulley/harmonic balancer. Its one piece. On the camaro, the pulley and balancer are two separate parts.
Old Feb 8, 2009 | 02:11 PM
Aardwolf's Avatar
Aardwolf
The early pulley is just a pulley, not part of the balancer. I have the aluminum March set and like them. The cost is reasonable for the two piece aluminum with steel alternator pulley. If you get the three piece set with aluminum alternator pulley the cost goes way up for some reason.
ladystoy69's Avatar
ladystoy69
i think you better take another look at that....it is 2pc on a older c4 vette just like camaro
pulley
Old Feb 8, 2009 | 02:31 PM
mseven's Avatar
mseven
I'm using a march ud on the crank and alt. The water pump is a asp racing pulley and std. rotation (all are allum.) w/no problems. I am currently waiting on a lightened p.s. puley.
The clearance to the crossmember is what I see becoming the issue when trying other crank pulleys.
Old Feb 8, 2009 | 03:00 PM
John A. Marker's Avatar
John A. Marker
I run the March underdrive pulleys on my 1985 (had to look yours up) same as yours. You would want to run the three set pulleys so that you spin the alternator at the same speed. Without the alternator pulley many Forum members have experienced a drop in voltage output at idle. This seemed to be especially true when their cars had additional add ons that pulled power...amps etc.
When I added the March set of three...the alternator output actually went up.
Old Feb 8, 2009 | 04:37 PM
Aardwolf's Avatar
Aardwolf
Any more details? I was thinking of lightening the stock pulley but cutting sections out. I made a thread about it awhile back.
Old Feb 8, 2009 | 05:32 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Remember that the reason for running lighter pullies is to reduce the rotary inertia. When you reduce mass from the innards of the pulley, though you can cut some overall weight you have very little effect on the rotary inertia because here it's the mass farthest from the axis that contributes most to said inertia.
Old Feb 8, 2009 | 06:29 PM
Aardwolf's Avatar
Aardwolf
Yes, I was thinking of removing parts of the pulley more for cooling. My thread on it:
http://forums.corvetteforum.com/c4-t...oling-mod.html
Old Feb 8, 2009 | 06:34 PM
KoKane's Avatar
KoKane
pulley
My bad, I was talking about an LT1.
Old Feb 9, 2009 | 11:06 AM
mseven's Avatar
mseven
you can do it that way, and if it is being hand cut (no rotary table, or edm etc.) I would then have it balanced. I had ASP Racing make my w.pump pulley so that I can have a allum. ribbed pulley for the std. roataion w.pump (which matched the ud.% pulleys I already had). I am currently having them make/cut a lightened p.s. pulley (allum.). They typically are not cheap (approx. 100.) but will make anything you want (provided you give them dimesions), and be able to tell what combination in sizes will achieve what amount of ud. etc..
If interested the contact is Lee at ASP Racing, 877-928-8678.
since I have no air etc. I was always interested in doing soemting like this (just too daymn priecey though):
To aluminum pulleys?
