? on 383 buildup
How much Hp you looking to make?
4340 crank is nice but $$$ if not justified if under 450Hp.
The Vortecs are going to limit your cam choice as they only go .480 lift stock without mods/.540 ? with mods.
Add some $$ for mods and screw in rocker studs.
If running Vortec heads would look for a piston with smaller dish to get CR up; Vortecs have 64 cc chambers.
MAF will not be a limitation with retune;some have run in the 10's with MAF.
Cheaper , better options out there.
check out www.cnc-motorsports.com options
Example;
Scat 383 (w/ 4340 rods , not 5140 Summit ones )
$1300
http://www.cnc-motorsports.com/produ...397&CtgID=9016
$180 extra gets balance , new flexplate and balancer.
Same with a cast steel crank
$800
http://www.cnc-motorsports.com/produ...215&CtgID=9212
$$$ you save on crank could go towards a set of Alum heads with no valve lift restrictions
If you drop back to a cast crank , can get assembled short block (4 bolt, not 2 bolt like yours ) with warranty for $1700.
Save on machining costs and sell your old engine to get some $$ back
http://cgi.ebay.com/ebaymotors/CHEVY...3A1|240%3A1308
Lots of options out there.
In that position, you will have enough clearance to turn the distributor when setting the initial timing without the extension hitting either the firewall or the plenum.
In fact, though, the distributor can be pointed in any direction; the engine doesn't know or even care where the plug extension is pointed. All it cares about is how the wires are routed and where the rotor is pointed.
Remove the #1 spark plug and stick your finger in the hole. Now, with the distributor cap plug extension pointed at 3:00 o'clock, bump the engine until you feel a pressure build up at the #1 hole. When you do, you'll know that the #1 is on the compression stroke. You can unplug the BAT wire if you want to if you're concerned about the engine starting.
Now remove the cap and check the rotor tip. It should be point very close to the #1 wire terminal of the cap; the terminal where the #1 wire is plugged in.
If it's not, you may have to remove the distributor and turn it one-tooth (one tooth of the distributor oil pump drive gear) to position the gear so that it does.
After moving the gear one tooth, recheck the rotor positioning as above.
As I said, positioning it that way, at 3:00, gives you the most adjustability but also allows your plug wires to reach from the plug to the cap.
That's how I do it.
Jake
