does anyone have 4.10 gears with automatic
Old Feb 9, 2009 | 12:16 PM
bigwave71's Avatar
bigwave71
Default does anyone have 4.10 gears with automatic
does anyone have 4.10 gears with a automatic, specifically a 700r4. need to know how it does when it hits overdrive in the quarter mile. does it bog down or does it still pull very good? also how does it do in first, does it blow the tires off it or does it hook good? i know tires have a lot to do with that but generally how does it do?
Old Feb 9, 2009 | 01:47 PM
383vett's Avatar
383vett
I run 4.30s in my bracket car with a 4L60e. I go through the traps at 6400 in 3rd gear. Car launches hard (1.42 50') but I'm running slicks. In my opinion, if you are hitting overdrive in the quarter, you've got too much gearing. The 3-4 clutchpack will not last.
Old Feb 9, 2009 | 02:16 PM
bigwave71's Avatar
bigwave71
im not hitting overdrive yet with my 3.54 gear, when i go threw the trap im at about 6000 rpm. im thinking with street tires and spraying out of the hole (thats what im doing now) that im going to spin the tire even more causing the rpms to be alot more at the other end. ok thanks for the info looks like that might be to much gear. i would use slicks but i really dont go to the track enough to justify the cost. thanks again
Old Feb 9, 2009 | 03:22 PM
383vett's Avatar
383vett
I used to run 3.73's when the car was a street/strip car and that was a good combination for me. Why not spray after 2nd gear instead if during the launch if you're concerned about spinning.
Old Feb 9, 2009 | 06:15 PM
bigwave71's Avatar
bigwave71
i was doing that but i picked up 3.5 tenths by spraying out of the hole. i was thinking about the 3.73s those would probably be perfect for me. thanks
Old Feb 10, 2009 | 06:12 PM
JOHN89's Avatar
JOHN89
What are your times? N/A vs spray? Juice from launch vs after shift into 2nd? I am spraying once I hit 2nd and lifting between gear change into 3rd. I went 11.42 @ 120. I always wonderd how it would go right from the launch.
John
Old Feb 10, 2009 | 08:03 PM
bigwave71's Avatar
bigwave71
John
my times when i hit the nos in 2nd are 12.30s and when i hit it out of the hole 12.0s at 122 mph so i see the mph and looks like im spinning so a 4.10 gear im thinking will make that even worse.
Old Feb 10, 2009 | 08:57 PM
JOHN89's Avatar
JOHN89
Your mph looks good. Did it increase much when you hit the juice right off the line? What is you 60' time? That should tell you if you are spinning. Unless your bogging.
John
Old Feb 10, 2009 | 09:01 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
I ran 4.10 with the Lt1 and they worked great, but never hit OD. That however wasn't the same when I put 4.88 in the car. Maybe I should of used OD. This was a bit to much for the stock bottom end.
Old Feb 10, 2009 | 09:36 PM
bigwave71's Avatar
bigwave71
do you remember what the rpms were when you crossed the line?
Old Feb 10, 2009 | 09:39 PM
bigwave71's Avatar
bigwave71
John
ill have to dig the ticket out to get the 60 foot times and i will check on the mph when i hit it i 2nd. im at work right now, i will check tonight when i get home.
Old Feb 11, 2009 | 03:20 AM
bigwave71's Avatar
bigwave71
John
my 60' was 1.897 sec
Old Feb 11, 2009 | 07:57 AM
TA's Avatar
TA
Very cool picture
A little off the topic, but what kind of rear spoiler is that. I haven't seen any like that before. Almost looks like a C5 type. Subtle, but cool
Old Feb 11, 2009 | 10:19 AM
NEVRL8T's Avatar
NEVRL8T
Originally Posted by TA
Very cool picture
Old Feb 11, 2009 | 10:40 AM
mackeyred96
With the 4.10 it was in the 6500 range.
Old Feb 11, 2009 | 01:34 PM
383vett's Avatar
383vett
Very cool picture
Thanks, this was a body kit sold by Mid America Corvettes about 12-15 years old. It utilizes c5 lights and an integrated rear spoiler. For some reason, the pictures shows what could be interpreted as a perfect seam where the spoiler meets the bumper, but in actuality it is all 1 piece. I don't think Mid America markets this bumper any longer. Also sorry to be off topic. Willie
Old Feb 11, 2009 | 01:39 PM
bigwave71's Avatar
bigwave71
thanks thats about what i figured and that will definatly be to many rpms for me.
Old Feb 11, 2009 | 07:20 PM
93 ragtop's Avatar
93 ragtop
mine runs 6550 at 117mph. This was on ET Street Bias ply 26x11.5. Verified with data master on the rpm. MPH by the track!
To does anyone have 4.10 gears with automatic
