Timming issues
Old Feb 9, 2009 | 04:47 PM
corvettewiz18's Avatar
corvettewiz18
Default Timing issues
What would cause the timing to jump around at idle. The shops diacom is showing timing at 12-15 then jumps to 25 then down to 12 then up to 17 and so forth. It just wants to die at idle. But when you drive timing stays fine??
Old Feb 9, 2009 | 05:06 PM
floridamale's Avatar
floridamale
Did you disconnect the EST wire first, if not the timing will move around. It needs to be disconnected to set base timing.
Old Feb 9, 2009 | 08:11 PM
corvettewiz18
yes they tried that
To Timming issues
