92 Vette Cam change
Old Feb 9, 2009 | 11:55 PM
chacal's Avatar
chacal
8th Gear
Default 92 Vette Cam change
Can a 92 lt1 corvette camshaft be changed with the engine on the car?
Has enyone done it?
Old Feb 10, 2009 | 11:29 AM
93lt1fun's Avatar
93lt1fun
Yes. You will have to remove the fan shroud, radiator, condensor and related parts to slip it out the front.
P.S. It would be better if you posted this to the Tech/Performance forum.
Old Feb 14, 2009 | 10:49 PM
calvette 11's Avatar
calvette 11
Default cam
Has enyone done it?
It can be done.Use service manual no problems.Most difficult part
is the hub.replace all the seals in the cover and the spocket
To 92 Vette Cam change
