160 STAT
Old Jan 23, 2002 | 07:20 PM
STL94LT1's Avatar
STL94LT1
Default 160 STAT
After installing a 160 thermostat, how do I reprogram my fan without a Hypertech programmer. I have a 1994 LT1.
Old Jan 23, 2002 | 07:22 PM
vader86's Avatar
vader86
Default Re: 160 STAT (STL94LT1)
well you cant without something to plug into your computer, not that i know of anyway. of course you could wire the thing to come on all the time, but you dont want to do that
Old Jan 23, 2002 | 10:16 PM
plastic thunder's Avatar
plastic thunder
You might find a speed shop that will do it for you without buying the unit :yesnod:
Old Jan 23, 2002 | 10:28 PM
emoshn's Avatar
emoshn
Default Re: 160 STAT (plastic thunder)
I installed a 160 stat...and didn't do anything. engine temp went down, so i was happy. Might have been my original 180 stat was stuck.
Old Jan 24, 2002 | 12:52 AM
Vic'89's Avatar
Vic'89
You can turn the fans on with a manual switch.
That is the setup I have.
Just a plain old toggle switch to ground the fan relays.
Vic
Old Jan 24, 2002 | 12:57 AM
mikes84vette's Avatar
mikes84vette
Default Re: 160 STAT (vader86)
why?
[Modified by mikes84vette, 10:58 PM 1/23/2002]
Old Jan 24, 2002 | 01:18 AM
jay17's Avatar
jay17
Default Re: 160 STAT (Vic'89)
Vic
I also have this. Doesn't do much when at speed or with a/c on (because both fans are on already). But when sitting in traffic and it's not a/c weather, it helps a lot. If the temp is sitting at 220 (second fan doesn't come on till 228) and I hit the switch the temp drop to 195-200. Also good when at the track.
To 160 STAT
