A/C control-fan motor-up-down WTF
Old Feb 11, 2009 | 10:55 AM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Default A/C control-fan motor-up-down WTF
At the begining of my project few of you recommended to me to change the A/C control vacumm lines plugs to fix the air from blowing from the bottom only while the A/C was at on at the regular setting (pictures below).
Yesterday, the air still blows from the bottom only. The defroster works properly.
Please give me direction here
Is it the dash board A/C control?
Is it the vacumm line under/next to the heater core?
Old Feb 11, 2009 | 02:38 PM
PLRX's Avatar
PLRX
2017 C4 of Year
Old Feb 11, 2009 | 03:52 PM
BobRR3's Avatar
BobRR3
Genneraly, If your fan if only blowing through the defroster and heater vents ( This is the default position ) It's "usually" one of two problems.
First, Check the three way vacuum check valve in the engine compartment. It's on the passenger side. Let me know if you need help finding it. This vacuum check goes to the Cruise control and also to the vacuum controller under the dash. For the most part, I can say that if your cruise control dosen't work, It's probably the check valve.
If your cruise control does work, It's most likely the vacuum controller connector. the vacuum controller is located under the dash ont he drivers side just above the gas pedal. The littlenipples on the connector close off after some time and you will need to replace the connector, not the box. I have already replaced mine and it now works great. post back and let me know what you find. I can guige you the relavent posts to fix the problem. good luck
Old Feb 11, 2009 | 04:06 PM
jimg's'93's Avatar
jimg's'93
I helped a friend out with just this problem not too long ago abd yes, it was the actual vacuum controller that was bad. I replaced it and all was well!
Old Feb 11, 2009 | 04:28 PM
PLRX's Avatar
PLRX
2017 C4 of Year
I already replaced the vacuum controller connectors. see picture
Old Feb 11, 2009 | 09:50 PM
jimg's'93's Avatar
jimg's'93
Not the connectors....the vacuum control box itself that has the vacuum 'octopus' plugged into it.
Old Feb 11, 2009 | 11:30 PM
PLRX's Avatar
PLRX
2017 C4 of Year
Good, I did not throw it away. I'll use the one I bought to use the "octopus" I think is the same unit.
Old Feb 12, 2009 | 08:39 AM
jimg's'93's Avatar
jimg's'93
Keep us posted. My money says that fixes your woes.
Old Feb 18, 2009 | 08:47 PM
jimg's'93's Avatar
jimg's'93
Kinda curious to know if that fixed your prob...
Old Feb 26, 2009 | 02:41 PM
PLRX's Avatar
PLRX
2017 C4 of Year
I tried that and found a hole in the vacuum line. The AC is now blowing air normally. I bought the AC cans at the local auto parts and it is nice and cold
To A/C control-fan motor-up-down WTF
