Injector Testing/Cleaning?
Old Feb 13, 2009 | 04:50 AM
Donne Trav's Avatar
Donne Trav
Default Injector Testing/Cleaning?
Can the fuel injectors be tested & cleaned at home? Has anyone of
you ever done this in the past? Thankyou all.
Old Feb 13, 2009 | 05:04 AM
RRT vette's Avatar
RRT vette
http://www.cruzinperformance.com/fuelinj.html
Old Feb 13, 2009 | 11:30 AM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
For the cost of cleaning + a couple of bucks go to FIC and get new Bosche III's I did and they make a difference.To answer the question No you cannot do it correctly at home.
Old Feb 13, 2009 | 12:14 PM
SunCr's Avatar
SunCr
Posters - in the past - have used a graduated beaker with some means to energize the injector (you can buy a tool for about 80 Bucks at NAPA) and flow tested at home. OR you can use the tester with a Pressure Gage and note the pressure drop on each injector when momentarily energized. However, on most pressure gages, it's difficult to read minute, 2 or 3 psi differences, between injectors. Of course if you find a problem you still have to come up with some means to repair/clean or replace the faulty injector so buying new or sending yours out for a rebuild is probably more cost efficient.
To Injector Testing/Cleaning?
