Is this true?
Old Jan 24, 2002 | 09:17 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Is this true?
Guys,
I thought I read somewere were the 89 TPI and earlier fuel injestion system fire all injectors at the same time. Is this true? Then it wouldn't matter if the wires were switched from one injector to another? NOT that I would do that, but just trying to get things straight in my head. Thanks and sorry about the stupid question. I have a lot of little facts in my head and sometimes I start doubting myself. Just need to check my systems.
Old Jan 24, 2002 | 09:22 AM
-=Jeff=-'s Avatar
-=Jeff=-
Default Re: Is this true? (ski_dwn_it)
sort of...
the 89 TPI system would fire the left side bank (all 4) then the Right side bank (all 4)
basically for what it takes the motor to run through all 8 cylinders each bank fires twice
Old Jan 24, 2002 | 11:43 AM
bogus's Avatar
bogus
what he said!
it is called a batch fire system. To provide more fuel at higher RPMs, they fire twice, instead of longer....
batch did'nt go away until 1994, when they went to sequencial. The computer power was just not readily available to get it done.
Old Jan 24, 2002 | 12:10 PM
-=Jeff=-'s Avatar
-=Jeff=-
Default Re: Is this true? (bogus)
what he said!
Also keep in mind on the 1994 and up LT1's it is only sequential at the lower RPM. to my knowledge at the Higher RPM is acts like the Batch system
Old Jan 24, 2002 | 03:06 PM
Vic'89's Avatar
Vic'89
The left 4 injectors fire together and the right 4 injectors fire together.
It is the basic batch fire system.
Vic
Old Jan 24, 2002 | 03:14 PM
LPDesRoche's Avatar
LPDesRoche
Default Re: Is this true? (Vic'89)
Yes you can swap the injector connectors on the same side. Its an easy way to test the injector drivers/wiring harness.
Old Jan 24, 2002 | 06:55 PM
David-F's Avatar
David-F
All 8 injectors operate together they have a left and right power feed and left and righ leads going to the ECM on your 85 to 91 then in 92 and 93 with the use of two O2 sensor the left and right operated independent of each other kind of like two 4 cylinders put together, then starting in 94 they went to sequential fuel injection but again it is like two 4 cylinders left side used the right Os sensor and the left side used the right O2 sensor all four injectors on the left or right operated the same thy just opened just before valve opening and yes if the harnesses get switched you can get a little roughness at idle. The batch firing was all that was needed to meet emission standards at that time then with increased need for cleaner operation they went through stages from 1 O2 sensor to 2 splitting the engine in half to the final sequential which is just a little better at controling emission. The ZR1 was also sequential from 90 to 95.
David Fulcher
To Is this true?
