Fan temp settings for late model C4?
Old Jan 24, 2002 | 10:40 AM
Woodstoc's Avatar
Woodstoc
Default Fan temp settings for late model C4?
Anyone know what the settins are for the electric radiator fans on a 96? My wife's first fan is coming on at about 220 deg F. Turn on the A/C and the fans come on as expected. This seems high to me. I replaced both primary and secondary fan relays and they still come on this high.... :confused:
Old Jan 24, 2002 | 10:47 AM
Springer's LT4's Avatar
Springer's LT4
Cruise-In III Veteran
Default Re: Fan temp settings for late model C4? (Woodstoc)
Thats about right.. my 95 is the same.
Old Jan 24, 2002 | 11:56 AM
jeepie91's Avatar
jeepie91
Thats close, and yup I think it is too hot also. You can have the fan on and off temps changed by reprogramming the
chip, also change the thermostat to a 160 or 180 and that should help.
Old Jan 24, 2002 | 12:08 PM
jvesalga's Avatar
jvesalga
I have an 84 and that is about right. I thought mine was a bit high as well so I changed the fan switch to a 95c degree unit. Now the fan will comes on about 208 and runs much cooler. The optimal temp. for a small block is around 200 degrees.
Old Jan 24, 2002 | 03:02 PM
jay17's Avatar
jay17
The second fan comes on a 228 with a/c off.
Old Jan 24, 2002 | 03:27 PM
C4 4Me's Avatar
C4 4Me
Cruise-In II Veteran
Default Re: Fan temp settings for late model C4? (jay17)
220 is the right temperature. Now I am sure we can start a debate that has been had here many times whether this is too high or not.
There is merit to both sides, I'll stick with what the factory did.
Old Jan 24, 2002 | 04:50 PM
Woodstoc's Avatar
Woodstoc
Thanks for the input everyone. I'll leave as is. I am used to running my 82 at 180.
To Fan temp settings for late model C4?
