installing ford 9" solid axle.
Old Feb 18, 2009 | 05:45 PM
Dgregory's Avatar
Dgregory
Default installing ford 9" solid axle.
can anyone tell me what it takes to install one in 85 vette.
Old Feb 18, 2009 | 05:59 PM
ArmyBoyATC's Avatar
ArmyBoyATC
I would also like to know what it takes to do this. If you find out anything please let me know!
Old Feb 18, 2009 | 06:09 PM
BTTB's Avatar
BTTB
Default r/end
Do a search in in advance search archives--there should be alot of posts on this topic---theres a guy in Pa--jesse azatto--that does the rear ends
Old Feb 18, 2009 | 07:07 PM
Iroc57's Avatar
Iroc57
There is a member that does kits
Around $5000 for a 9" if I remember correctly but I don't remember the name of the member. Once the search is back a "solid rear" search should get you there
Found it
http://forums.corvetteforum.com/c4-t...sion-kits.html
Old Feb 18, 2009 | 07:21 PM
Dgregory's Avatar
Dgregory
Default 9"install
Found it
thanks
Old Feb 18, 2009 | 07:39 PM
WVZR-1's Avatar
WVZR-1
Any "solid-axle" install requires "serious thought" and conversations with "serious chassis builders"! A serious "chassis builder" should be able to supply you with prior installs and I would speak to "several previous" customers! You want to "inspect" a few of the builds also!
"serious thought" - "serious chassis builders"!!!!
A 5K install that "doesn't work" can cost maybe that + to correct!!
Old Feb 18, 2009 | 08:54 PM
rodj's Avatar
rodj
http://forums.corvetteforum.com/drag...-axle-kit.html
http://forums.corvetteforum.com/c4-t...cs-inside.html
Old Feb 18, 2009 | 11:05 PM
ambassadorgodzilla's Avatar
ambassadorgodzilla
$5k in parts is less than the surgeon charges to drill the hole in your head and suck out half your brain before you do this.
And now for something completely different...
What possible purpose would such a swap serve? Drag racing, maybe?
Old Feb 19, 2009 | 12:56 AM
rodj's Avatar
rodj
Did you read the first link I posted?
People with serious Hp are breaking D44's on the strip especially with manual cars and sticky tires.
Some light reading
http://forums.corvetteforum.com/c4-t...ic-limits.html
Old Feb 19, 2009 | 05:44 AM
93 ragtop's Avatar
93 ragtop
Carrolls Rods and Racecraft makes a kit for this purpose. IMO its the best out there!! There are a few people on here who have it. Mackeyred 96, Insanaty? Tensecvet? (not sure if names are spelled correct).
But, as posted earlier, make sure you get a professional chassis builder to do this. Ill go even further and say do a search and check out reputations and how well they stand behind their work. Ask for references from people who have actually used their product before laying down that kind of money.
One other thing. Post this in the drag section and you may get more responses.!!
Good luck with your decision.
Old Feb 19, 2009 | 09:55 PM
ambassadorgodzilla
Sorry, I missed the original post.
Old Feb 19, 2009 | 11:43 PM
383vett's Avatar
383vett
I went with a custom fabricator for my Strange,12 bolt. Paid much more than the bolt in systems on the forum, but have had no issues over the past 2 years. With the Dana 44 every year there were at least a couple incidences of broken somethings. Now I can just race and not worry about ending up in the wall. Willie
Old Feb 20, 2009 | 09:01 AM
Iroc57's Avatar
Iroc57
Hard to post an intelligent reply without that info I guess
Old Feb 21, 2009 | 08:46 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
If your interested in the solid axle conversion please get in touch with me. I have several in the pipeline now and can provide you with names of those that have already recieved them and you can contact them directly if you like for reference.
The setups come with everything you will need to make a clean install into the car. They do not require a crossmember that NO other system offers on the market (crossmembers drastically reduce the clearance under these cars and will hit eveything; our setups do not need this), also our setup is the only FULLY adjustable 4link which is no different than a purpose built chassis car would be equipped with.
I have been running one coming up now on 3 seasons and have not had a single problem since I installed it. Before I was breaking the D44 about every few runs.
Best 60ft on my n/a 434 was 1.31 with the rear wheels breaking the beams! And those that have seen my car know its not just a shell, it still has a full interior, power everything, stereo etc.
These setup flat out work in these cars that truely do make an awesome drag car since they are already very well balanced.
Any questions please let me know.
Regards,
Old Feb 21, 2009 | 01:17 PM
383vett's Avatar
383vett
Regards,
Hi Jessie, good to hear from you. How is Zabaz's set up coming along. I told you he would be giving you a jingle. Willie
Old Feb 22, 2009 | 04:46 AM
j-stingray's Avatar
j-stingray
go with jesse`s setup
you'll never look back [believe me i know ]
Old Feb 22, 2009 | 06:36 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Zabaz's setup is about 90% complete and will be putting the finishing touches on it this upcoming week.
J-Stingray - Thanks for the nice comments.
To installing ford 9" solid axle.
Old Feb 24, 2009 | 04:01 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
Jessie, I though you were working and not playing on the form
Lets get back to work on my rear end ,those 5 kids need the money
Yes their are a few of us on the form that will trust Jessies rear.
Just sell yours and invest in Jessies
Old Mar 1, 2009 | 08:16 PM
tensecvet's Avatar
tensecvet
Here's my www.rodandracecraft.com C-4 pro BOLT-in KIT for $4995$. the also have slower kits ( less$$$ ) , you should call the shop . great guys at the shop too. the also have a c-5 bolt-in kit. they are true RACE CAR builders. my cars best so far allout 8.30 169mph in a bolt in kit.the kit was built just for 8.50 index classes We did the install in our own garage , easy to put in. the shop has TONS of c-4 kits for brakes and roll bars rears .
where do you think the others talked too before they made it.
Old Mar 2, 2009 | 09:28 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Guys,
Thanks for the IMs and calls about the setup. As a result, I thought I would post some photos of the setup and list some of the details outlining the benefits of the setups:
-Wishbone Locator - the absolute best way to positively locate a rear without binding, used in ALL purpose build chassis cars!!
-No crossmember required meaning no ground clearance issues. And you WILL have groundclearance issues if you drive your car on the street with a crossmember. As a result, that is why we designed our kits so there is NO crossmember required.
- Fully adjustable front and rear 4 link brackets - a must for racing!!
- Fully adjustable shock mounts - a must for racing!!
- The FIRST fully bolt-in C4 setup on the market.
- Stock brakes and wheels will work with our setup and brackets (included with every kit)
- Integrated anti-roll bar that keeps the car perfectly level on launches and when the car's front wheels are in the air ( watch signiture for illustration!!)
click photo for slideshow:
Click Photo for SlideShow of setup installed in car:
More information can be found by following the links in my signiture.
