ECM programming software
Old Jan 24, 2002 | 10:50 PM
GlockLT4's Avatar
GlockLT4
Default ECM programming software
Ok, since there aren't enough people over in the ECM/PCM section...
I need a program that I can write to my PCM with ... the Tuner cat program flshprog.exe isn't working.. i get error code 5 every time.
Anyone know of a program I can use?!? I need this before I can drive my vette around. I have to change the idle and cube #'s
Old Jan 24, 2002 | 11:22 PM
ChrisB's Avatar
ChrisB
Default Re: ECM programming software (Glock'94)
The two options out now are tunercat or lt1 edit. If tunercat doesn't work then there is something else wrong. I would try using another laptop first if you can (or a desktop) - make sure all your power saving features are turned off, etc. Does TTS Datamaster log any errors.
If you are in plano I will be up there not this weekend but next and can flash it for you.
Old Jan 24, 2002 | 11:28 PM
GlockLT4's Avatar
GlockLT4
Default Re: ECM programming software (ChrisB)
I'll try my roommates laptop.. see if that works. No, I'm not in Plano .. I'm back at school in Norman
To ECM programming software
