MAP levels
Old Jan 25, 2002 | 12:37 AM
GlockLT4's Avatar
GlockLT4
Default MAP levels
Shouldn't MAP levels go UP when you give a car throttle? Mine's going down. I think it may be related to a vacuum leak I've got from a piece broken during the engine work.
Old Jan 25, 2002 | 11:11 PM
GlockLT4's Avatar
GlockLT4
Default Re: MAP levels (Glock'94)
TTT!
Old Jan 26, 2002 | 12:26 AM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
Yep, you are absolutely right.
MAP output follows the throttle. Up=Up Dn=Dn.
Voltage should be around 1-2 volts at idle and increase to 4 to 5 volts at WOT.
There should be THREE wires attached to your MAP sensor.
Ground -
+5 volts from the ECM
MAP Output -- Varies With Manifold Pressure
Good luck with it!
Old Jan 31, 2002 | 02:50 AM
Mo_Bandy's Avatar
Mo_Bandy
Default Re: MAP levels (VetNutJim)
Glock
It definately goes up... My stock 1 bar MAP reads 103 KPa at 8 pounds of boost for me (WOT) .. around 40 KPa at idle orabout 11.8 hg at idle and 30.4 hg at WOT being normally aspirated yours will be probably a little lower at idle and not near as high at WOT
For what its worth... MO
To MAP levels
