R & R Harmonic Balancer
Old Feb 21, 2009 | 09:04 AM
floridamale's Avatar
floridamale
Default R & R Harmonic Balancer
A few weeks ago while replacing the gear on my distributor I noticed the timing mark had moved on my harmonic balancer. 87 L98 auto so I knew I needed to replace the balancer before it worked its way back into the timing cover and did more damage. I have to say it was much easier then I thought it would be about 2 ½ hours, I didn’t have to remove the power steering lines off the rack, I did remove the water pump pulley, and used an old trick of locating a ratchet against the frame and bumped the motor to loosen the crank bolt. I did use a puller but not a install tool, instead I just used a longer bolt and washers to install new balancer stock bolt is 2 ¼ inch 7/16 fine thread, there is a metric number as well but the 7/16 was the same. I used a 3 inch bolt to reinstall; then used the stock bolt, no one around here had an install tool in stock. Feel much better now about driving it not having to worry about a more serious problem.
Old Feb 22, 2009 | 02:20 PM
JAKE's Avatar
JAKE
Yep, looks like it moved, alright. Nice work.
Jake
Old Feb 22, 2009 | 03:15 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
hood catch
To R & R Harmonic Balancer
