Speed Bleeder Problem
Old Feb 21, 2009 | 05:05 PM
dan6712cc's Avatar
dan6712cc
Default Speed Bleeder Problem
I just installed a set of speed bleeders in my '94 (SB1010), however on the rear calipers they stick out with threads showing about 1/4 inch. Is this normal? The front calipers are the C5 version and I put SB1010S on those and they fit flush. Anyone else have this problem?
Old Feb 21, 2009 | 06:17 PM
WVZR-1's Avatar
WVZR-1
I don't know that it's actually a problem!
So long as they function properly I'd say you're good to go. The part # seems correct and when "bottomed" they actually function and seal just like an OEM. A Russell application for the C4 says 33 mm long and yours mention 34.4. I would guess the extra threaded length would accomodate a caliper with a substantially deeper bleeder bore. Did you compare the two "side by side".
I'd be interested to know the overall length of what you removed from your "rears"!
Old Feb 21, 2009 | 09:14 PM
Sidney004's Avatar
Sidney004
Mine are the long version as well, no problem.
Old Feb 22, 2009 | 02:33 AM
GKK's Avatar
GKK
The Earl Solo-Bleeds I just installed have a 27mm length, which fit the front and rear calipers exactly the same as the stock bleeders did.
Old Feb 22, 2009 | 08:04 PM
the blur's Avatar
the blur
do they leak?
have a firm pedal ??
Old Feb 22, 2009 | 08:12 PM
dan6712cc's Avatar
dan6712cc
After I took a second look at them they would seem to work fine as they did seal. I ended up removing them and replacing with OEM however because I just realized I cant do reverse bleeding with a phoenix injector with the lock valve the speed bleeders have. BTW I have never gotten a clutch to feel as good as it does now with that phoenix injector using RFI so I am looking forward to see how the brakes feel after I finish.
To Speed Bleeder Problem
