Wheel Center Cap locks
Old Feb 22, 2009 | 09:00 PM
Bama_Breeze89's Avatar
Bama_Breeze89
Default Wheel Center Cap locks
Hey Guys,
I have a 89 vette with the factory 17 inch wheels. They have the center caps that cover the lugs. These center caps have the factory locking screws on them. My problem is I dont have the key to unlock these caps. As I dont want to mess up the caps does anyone have an idea to get the locking screws out of these caps with out damaging the center caps? I have called around to some local dealers and they dont dont want to mess with me. I have also dropped by some tire shops and they dont have a good idea either.
Thanks guys.
Old Feb 22, 2009 | 09:45 PM
l98tpi's Avatar
l98tpi
Max G’s
Call a Chevy Dealer and get a key blank and/or key code and go to locksmith and get a key cut. Although you may be able to get the key from the dealer.
Old Feb 22, 2009 | 10:28 PM
Bama_Breeze89
okay,,, well im looking for a lug type key not the inigition key.
Old Feb 23, 2009 | 12:05 AM
RatC4's Avatar
RatC4
I've been there too. A big easy out and a drill. I used the square tapered type of easy out not the spiral kind. I don't recall the size drill bit maybe 5/16. It turns out the bolts are not hardened so they drill pretty easily. Good luck and have fun.
Old Feb 23, 2009 | 12:18 AM
redrose's Avatar
redrose
"left hand" drill bits MAY remove the "lock" while drilling...centerpunch before drill...after you remove the locks, take one to your local "fastenal" bolt store and get socket head (allen wrench) stainless steel bolts (they're metric,btw) to replace the "locks" (unless your local thief types carry metric allen wrenches)
Old Feb 23, 2009 | 12:20 AM
Hooked on Vettes's Avatar
Hooked on Vettes
Contact this company. They made the puzzle locks used on the 88 and 89 17" rims.
Tell customer service you lost the removal tool, don't have the key code and that GM no longer supports the item.
You can fax them or e-mail an image of the lock pattern and for a small fee they will send you the correct key lock removal tool.
http://www.mcgard.com/Home/ContactUs
Old Feb 23, 2009 | 01:03 PM
Bama_Breeze89
Thanks for the information
Old Feb 24, 2009 | 02:21 AM
Movnviolation's Avatar
Movnviolation
Mcgard can't help ya. Been there done that! Drill and use easy out. It's a piece of cake!
Old Feb 24, 2009 | 02:34 AM
khhammer's Avatar
khhammer
Had the same problem with the puzzle style locks . Discount tire had a special tool and took them off in seconds. Undamaged.
To Wheel Center Cap locks
